[Swift-devel] submitting jobs to the queue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Mar  9 11:28:22 CST 2007
On Fri, 2007-03-09 at 11:21 -0600, Tiberiu Stef-Praun wrote:
> Knob means "while in progress"
> Is that doable ? (Probably extending your rudimentary debugger would do it).
> How about the  following extension: can we easily create hooks
> (webservices) into a running swift engine, that would allow this
> manipulation with an external client (the knob driver) ?
Possible it is. Easy, I'm not sure.
The problem consists of two things:
- making the engine support such knobs, and this depends on the exact
functionality needed. Updating scheduler properties is probably
straightforward.
- the interface (a service, a GUI, a TUI, etc.)
> Having more interactivity with a running workflow is something that
> might be appealing for long-running or never-ending workflows, and
> would differentiate us from others in a nice way. You would not
> believe how many people are working on workflows: everybody and their
> brother at the OSG meeting had some offering labeled "workflow".
That's not unbelivable. If you want to run non-trivial applications on a
big thing like OSG, you need some kind of workflow tool.
>  (I'm
> exaggerating a bit here)
> Tibi
> On 3/9/07, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Yes, although we need to come up with a nicer way to do it.
> > In libexec/scheduler.xml, change <property name="jobThrottle"
> > value="4"/> to value="large number" (not literally).
> > Mihael
> > On Fri, 2007-03-09 at 11:06 -0600, Veronika V. Nefedova wrote:
> > > Hi, Mihael:
> > > Is it possible to remove this feature in the one site case ? For example,
> > > the queue is now almost empty on TG, but I have to wait for 1.5 hours for
> > > the rest of my jobs to be submitted (thats the average running time of my
> > > job) - and the queue might be full by that time...
> > > Nika
> > > At 04:36 PM 3/7/2007, Mihael Hategan wrote:
> > > >On Wed, 2007-03-07 at 16:30 -0600, Veronika V. Nefedova wrote:
> > > > > Hi,
> > > > > I've noticed one very strange behavior. For example, I have 68 jobs to be
> > > > > submitted to the remote host simultaneously. Swift submits at first
> > > > just 26
> > > > > jobs. I checked that several times - its always 26 jobs. Then, when at
> > > > > least one job out of those 26 is finished - swift goes ahead and submits
> > > > > the rest (all of those left - 42 in my case).
> > > > > Is it a bug or a feature?
> > > >Feature. Although it should probably be tamed down in the one site case.
> > > >Each site has a score that changes based on how it behaves. If a site
> > > >completes jobs ok, it gets a higher score in time. If jobs fail on it,
> > > >it gets a lower score.
> > > >Now, let's consider the following scenario: 2 sites, one fast one slow.
> > > >With no scores and no limitations, half of the jobs would go to one, and
> > > >half to the other. The workflow finishes when the slow site finishes
> > > >half the jobs.
> > > >What happens however, is that Swift limits the number of initial jobs,
> > > >and does "probing". This allows it to infer some stuff about the sites
> > > >by the time it gets to submit lots of jobs. It should yield better
> > > >performance on larger workflows with imbalanced sites, which is, I'm
> > > >guessing, our main scenario.
> > > > > Nika
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
