[Swift-devel] strange exceptions
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Tue Mar  6 16:22:24 CST 2007
Yes, I got the prompt back. And all the previous stages of the workflow had
no problems with files staged in/out. The output from that last stage was
never produced...
I'll check the parameters to see if that could be the problem.
Nika
At 04:15 PM 3/6/2007, Mihael Hategan wrote:
>Do you get the shell prompt back?
>Is that gridftp server actually working?
>Mihael
>On Tue, 2007-03-06 at 16:15 -0600, Veronika V. Nefedova wrote:
> > I do not see any output neither on the remote host nor on the localhost.
> > And I have this on stdout (where I submitted the workflow):
> > <snip>
> > chrm failed
> > chrm failed
> > chrm failed
> > <many times>
> > <snip>
> > At 04:09 PM 3/6/2007, Mihael Hategan wrote:
> > >On Tue, 2007-03-06 at 16:09 -0600, Veronika V. Nefedova wrote:
> > > > It looks like it...
> > >Can you be more specific?
> > > > At 04:04 PM 3/6/2007, Mihael Hategan wrote:
> > > > >Does the workflow fail?
> > > > >On Tue, 2007-03-06 at 16:02 -0600, Veronika V. Nefedova wrote:
> > > > > > Hi,
> > > > > > I got some very strange exceptions while running the workflow:
> > > > > > 2007-03-06 15:20:50,741 INFO  vdl:execute2 Creating temporary
> directory
> > > > > > swift-MolDyn-free-kh02i75488k02/chrm-libtl78i on TG-NCSA
> > > > > > 2007-03-06 15:20:50,823 DEBUG vdl:execute2 Application exception:
> > > > > Failed to
> > > > > > check if
> > > /home/ac/nefedova/SWIFT/swift-MolDyn-free-kh02i75488k02/chrm-libtl78i
> is a
> > > > > > directory
> > > > > >          task:dir:make @ vdl-int.k, line: 340
> > > > > >          vdl:execute2 @ execute-default.k, line: 22
> > > > > >          vdl:execute @ swift-MolDyn-free.kml, line: 217
> > > > > >          charmm3 @ swift-MolDyn-free.kml, line: 4619
> > > > > >          vdl:mains @ swift-MolDyn-free.kml, line: 3395
> > > > > > Caused by:
> org.globus.cog.abstraction.impl.file.FileResourceException:
> > > > > > Failed to check if
> is a
> > > > > > directory
> > > > > > Caused by: org.globus.ftp.exception.ServerException:  Custom
> message:
> > > > > Could
> > > > > > not create MlsxEntry [Nested exception message:  Custom message:
> > > Expected
> > > > > > multiline reply] [Nested exception is
> > > > > > org.globus.ftp.exception.FTPException:  Custom message: Expected
> > > multiline
> > > > > > reply]
> > > > > > My files are on wiggum in /sandbox/ydeng/alamines. The log is
> > > > > > swift-MolDyn-free-kh02i75488k02.log
> > > > > > Thanks,
> > > > > > Nika
> > > > > > _______________________________________________
> > > > > > Swift-devel mailing list
> > > > > > Swift-devel at ci.uchicago.edu
> > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
