[Swift-devel] Documentation for hierarchical mappers ?
    Yong Zhao
    yongzh at cs.uchicago.edu
    Mon Mar  5 10:52:55 CST 2007
Hi Ben,
When you finish the text part, let me know the xml format and I'll
incorporate that into the xml->kml part. Thanks.
Yong.
On Sat, 3 Mar 2007, Ben Clifford wrote:
> On Fri, 2 Mar 2007, Tiberiu Stef-Praun wrote:
> > It seems that we will not have very soon string concatenation, so at
> > least this specialized mapper would do.
> string concat is not that far away - its one of the small set of 0.2
> deliverables so should be appearing in the next week or so. This is what
> needs to happen, I think:
>   i) text->xml parser needs to support pass-through of multiparameter
>      expressions (I might have that done in the next hour)
>       (me)
>   ii) xml->kml compiler needs to generate multiple arg karajan invocations
>       (me or yong)
>   iii) vdl:strcat function needs to be implemented, but as I think there's
>        already a karajan strcat with the right semantics it should be
>        straightforward to implement vdl:strcat as a wrapper.
>        (mihael, maybe yong?)
> I'm working on i) at the moment.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
