[Swift-devel] Re: [Swift-user] New Java exception when moving	from rc3
    Ben Clifford
    benc at hawaga.org.uk
    Fri Mar  2 19:07:38 CST 2007
On Fri, 2 Mar 2007, Mihael Hategan wrote:
> The log4j file should include DEBUG on the loader (which should give the
> full stack trace of such). This is as of r367.
it doesn't do so in the r526 build I have:
swift -debug fmri.swift
Recompilation suppressed.
Using sites file:
/Users/benc/work/vdl2/cog/modules/vdsk/dist/vdsk-1.0/bin/../etc/sites.xml
Using tc.data:
/Users/benc/work/vdl2/cog/modules/vdsk/dist/vdsk-1.0/bin/../etc/tc.data
Swift V 0.0405
RunID: vu60fptpjhv70
Execution failed:
        java.lang.NumberFormatException: null
I rsynced directory from my laptop to ci:~benc/swift-fmri if you want to
look at what I have around.
Logs look like Chad's, pretty much.
> On Fri, 2007-03-02 at 23:21 +0000, Ben Clifford wrote:
> > I was a similar exception a couple of days ago on something i was playing
> > with but moved onto other stuff and never got round to looking closer -
> > the -debug option didn't give a stack trace and I never started digging
> > through the code.
> > On Fri, 2 Mar 2007, Chad Glendenin wrote:
> > > I'm still trying to run a workflow that worked with VDL rc3. With Swift
> > > snapshot 070301, the command-line argument works again, but now I get a Java
> > > exception:
> > > $ swift minmax.kml -list=filelist.txt
> > > Swift V 0.0405
> > > RunID: flkjse5yhp1c0
> > > Execution failed:
> > > Here's the code I'm trying to run.
> > > type file_t {};
> > > type filelist_t {
> > >    file_t file;
> > > (file_t output, file_t error) minmax (file_t input) {
> > >    app {
> > >        wrapper @input stdout=@output stderr=@error;
> > > //filelist_t dataset[] <csv_mapper; file="filelist.txt">;
> > > filelist_t dataset[] <csv_mapper; file=@arg("list")>;
> > > foreach f in dataset {
> > >    file_t out <regexp_mapper; source=@f.file, match="([^/]+).tar",
> > > transform="\1.out">;
> > >    file_t err <regexp_mapper; source=@f.file, match="([^/]+).tar",
> > > transform="\1.err">;
> > >    (out, err) = minmax(f.file);
> > > Here's my input file, 'filelist.txt':
> > > file
> > > /scratch20/chad/src/workflow/driventurb_3d_direct_plt_cnt_000340.tar
> > > /scratch20/chad/src/workflow/driventurb_3d_direct_plt_cnt_000341.tar
> > > Any idea what's causing the exception?
> > > By the way, the only reason I'm trying to upgrade is so that I can get
> > > disk-space management to work ("<profile namespace="SWIFT"
> > > key="storagesize">40000000000</profile>" in sites.xml). My understanding is
> > > that if I use VDL rc3, it could overrun the available scratch space and crash:
> > > I have 13.3 TB of data to process, but the UC/ANL TG site only has 1.1 TB of
> > > scratch space available. So if there's a way to enable scratch-space
> > > management in rc3, that should be good enough for now. (I'm a Swift user, not
> > > a developer, so I'd rather not be on the bleeding edge if I don't have to.)
> > > Thanks,
> > > ccg
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
