[Swift-devel] remote file/directory stuff (bug 22)
Ben Clifford benc at hawaga.org.uk
Fri Mar 2 11:58:14 CST 2007
On Fri, 2 Mar 2007, Yong Zhao wrote:
> Can you elaborate on this issue a little bit so that we can make a
> unanimous decision:
> 1. what was the problem exactly
Some programs that we run in swift do not use the traditional VDS-like API
of being told on the commandline the names of the files that they must
input and output to. Instead, they make up some of the names themselves.
For example, one of Nika's programs has the syntax:
 ./program inputfilename
and places its outputs in inputfile.stuff, inputfile.abc, inputfile.foo
> 2. what are you proposing
To extend the syntax of the app {} block to permit specification of the
above interface, with a syntax something like:
(stuffoutfile s, abcoutfile a, foooutfile f) myproc(inputfile i)
  app {
    program @i;
    s < @strcat(@inputfile,".stuff")
    a < @strcat(@inputfile,".abc")
    f < @strcat(@inputfile,".foo")
Meaning that rather than Swift specifying the remote name for s, a and f,
instead the app block specifies where those three files are.
These will be staged back into the submit-side location defined in the
existing mappers.
> 3. to what extent does the proposal solve the problem
It should solve Nika's immediate problem, I think.
> 4. what is the implication to the mapping interface
A longer term perspective is that this is the beginning of longer work to
implement fuller execute-side mappers (which have also been called
application mappers in some threads).
So it is mapping, but on the execute side. It fits in in a fairly
straightforward way with mapping on the submit side, which is what we have
now.
Submit side mapping maps between submit-side data and SwiftScript
variables/structures, so that the user can arrange his submit-side data in
a way that he wants (rather than swift compelling it to be in a particular
format)
Execute side mapping maps between SwiftScript variables and execute side
data, so that data can be laid out on the execute side in the way that the
program wants it (rather than swift compelling it to be in a particular
format)
With the present implementation, this amounts to being able to specify
different paths and filenames on the submit and execute side for each data
file.
In the longer term, it might also be useful in defining things like how to
map data on a submit-side database to some format on the execute side for
processing. If we have only submit side mappers, then we can map data
between a submit side database and SwiftScript structures, but not map
between those structures and the execute side...
