[Swift-devel] a different way to do array/structure accesses
Mihael Hategan
hategan at mcs.anl.gov
Wed Jun 27 15:58:03 CDT 2007
Probably not very efficient, for more than one reason. Also less clear.
I'd vote against it.
On Thu, 2007-06-28 at 02:16 +0530, Ben Clifford wrote:
> I've been playing round with converting the .xml intermediate format to
> be more strictly XML and less a mixture of XML and various other syntaxes.
> One thing that comes out of this is that its simpler in the parser and
> compiler layer to generate array and structure accesses using a bunch of
> karajan level calls, like this:
> <print>
> <parallel>
> <getfield path="a"><vdl:getfield var="{foo}" /></getfield>
> </parallel>
> </print>
> and
> <vdl:setfieldvalue>
> <argument name="var">
> </argument>
> <argument name="value">
> <number>9091</number>
> </argument>
> </vdl:setfieldvalue>
> instead of the way its done at the moment with a path syntax, like this:
> <vdl:setfieldvalue path="a" var="{foo}" value="9091"/>
> and
> <print>
> <parallel>
> <vdl:getfield var="{foo}" path="a"/>
> </parallel>
> </print>
> This allows a bunch of simplification to happen with path handling in the
> swift code. However, it makes the Karajan intermediate code more
> complicated. From the language side of things, I'd like to make this
> change, but I don't know enough about how that effects the load on
> Karajan, especially with the insanely large source files that people are
> machine-generating.
> (here's the program I pulled these from:
> type mytype { int a; int b; }
> mytype foo;
> foo.a=9091;
> foo.b=818;
> print(foo.a);
