[Swift-devel] Swift Performance Data
    Ben Clifford
    benc at hawaga.org.uk
    Mon Jun 25 09:07:22 CDT 2007
On Mon, 25 Jun 2007, Mihael Hategan wrote:
> This is similar to code generation vs. abstraction (or interpretation
> vs. compilation). There can be:
its also an issue with where the abstractions happen:
> 1. An api to access the logs in structured ways
needs the API to exist in the language that you want to write analysers
in.
> 2. A log translator
makes the API into a posix filesystem with text files. still needs a
per-language parser to parse that format, but that is 'simple' and works
in a variety of languages. so I'd favour this.
> 3. An adaptor plugged in at the log4j (or whatever logging library)
> level that does the translation dynamically (at the expense of
> performance).
Possibly some components can output stuff into a common format using log4j
- that wouldn't necessarily be any more dynamic than the existing log4j
output.
