[Swift-devel] Re: [Swft] Q about throttling
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 23 20:45:53 CDT 2007
On Sun, 2007-06-24 at 01:42 +0000, Ben Clifford wrote:
> On Sat, 23 Jun 2007, Mihael Hategan wrote:
> > > the use of the word 'factor' has a subtle implication that it is a
> > > relative load and so in the case of a single site will have no effect
> > It was discussed before that the algorithm could (and imo should) be
> > changed such that in the case of only one site, it would not throttle,
> > or at least the throttle would be significantly bigger.
> that or the name should change.
It's called "jobThrottle" and that's a bad name, too. Suggestions?
