[Swift-devel] Re: [Swft] Q about throttling
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 23 15:43:56 CDT 2007
On Fri, 2007-06-22 at 09:39 -0500, Mike Wilde wrote:
> Is there a configurable retry delay after failure?
> I think you need to examine the overall workflow dependency structure.
> Also, I recall from older perf charts that there's an option to enable/disable
> pipelining.  With pipelining disabled, it seems that Swift will wait for an
> entire dataset/foreach or procedure to finish before starting any tasks that
> depend on the foreach or procedure.
I don't think that was in swift.
> Mihael, can you look at some of these issues when you are back online and rested?
You say that as if I normally don't :)
> - Mike
> Ioan Raicu wrote, On 6/22/2007 9:06 AM:
> > No, I didn't keep track of this info, unless Swift does this through
> > some of its logs.
> > Over the last week, my observations have been the following: Swift is
> > more than capable and willing to send out many tasks as long as they are
> > independent (as can be seen in this graph where probably 6800 tasks got
> > submitted), but thereafter, it had no other burst of task submission,
> > although I believe it could have send out more.  For example, there were
> > 2500+ tasks that failed in the middle of those 6800 tasks (which were
> > all independent), why were 2500 tasks not resubmitted all at once...
> > they were each about 200 seconds long, so most of them should have
> > certainly showed up in the wait queue.
> > Ioan
> > Ben Clifford wrote:
> >>> kept busy, and the Falkon queue length was relatively at 0... so this means
> >>> that Swift was not submitting fast enough to keep all the executors busy.
> >> interesting. though around t=1000 there is a rapid burst of submission
> >> getting the queue length up to about 6000 in a few minutes.
> >> Do you know what the cpu time usage of the swift submitting JVM was over
> >> that time period?
> > Ioan Raicu
> > Ph.D. Student
> > Distributed Systems Laboratory
> > Computer Science Department
> > University of Chicago
> > 1100 E. 58th Street, Ryerson Hall
> > Chicago, IL 60637
> > Email: iraicu at cs.uchicago.edu
> > Web:   http://www.cs.uchicago.edu/~iraicu
> >        http://dsl.cs.uchicago.edu/
