[Swift-devel] on the semantics of 'array closing'
    Ian Foster
    foster at mcs.anl.gov
    Sat Jun 16 10:58:13 CDT 2007
Mike:
That's a great summary of requirements.
Ian.
Mike Wilde wrote:
> Hi all,
> I'm jumping in late; I re-read the thread a few times but may have
> missed something. So correct me as needed. Also, rather than spending
> more time polishing the thoughts below I just put them out here for
> discussion.
> This discussion seems to me very important, as it can close down
> several of the major open issues that are very critical to the
> language, both to give it complete and consistent semantics and to
> make it practical fr the problems that we are applying it to.
> Four important but missing aspects of this discussion are: pipelining,
> error handing, restart, and mapping.
> I feel that swift needs the following semantics:
> 1. Pipelining:
> The data dependency aspects of swift are carried out at the atomic
> level in a pipelined manner.
>  -- elements of an array are written into the stream
>  -- readers of the array consume the stream
>  -- the entire program remains active in parallel, across function
> boundaries
> Array elements [k,v] are identified by their index, k, which can be an
> int or string.
> 2. Error handling
> In practice, many large-scale foreach() operations will never
> complete, yet they will deliver a lot of useful results that we want
> subsequent statements in a program to continue to operate on. Thus
> closing needs to permit different criteria other than just "finishing".
> An array is "closed" when its producer function/foreach "shuts down".
> Can we permit shutdown/closing to occur based on finishing, time, or
> quota/threshold.  These would be parameters of the foreach statements
> that could be overridden.
> (For some practical examples, see map-reduce; it has similar problems:
> parallel computations reach a level whwre there is lots of
> parallelism, and as it proceeds, gets to a poiunt where only the
> "stragglers" are left - things waiting in slow queues or for hung data
> transfers, etc.  Ive read this in m/r papers, and found that our
> experiences match those reported by the google m/r people).
> 3. Restart
> We want computations to be restartable.  If 50% of a large
> array/dataset gets created in a 10-hour run, and then fails, we want
> the run to be restartable and continue where it left of with minimal
>  lost of "completed" results.
> 4. Mapping
> Lastly, swift mapping should be connected to this whole process: the
> mapped contents of a dataset should be a stream of xml elements rather
> than a "completed" xml document, so that we can practically handle
> very large datasets.  So when a foreach() statement processes  a
> array, its processing the mapped stream of the array. mappers should
> be parallel processes that produce and consume these streams of xml
> elements.
> - Mike
> Ben Clifford wrote, On 6/16/2007 8:34 AM:
>> On Sat, 16 Jun 2007, Mihael Hategan wrote:
>>>> It works because Swift implicitly marks arrays returned from
>>>> compound procedures as closed (which may or may not be correct).
>>> We defined it as correct. Something created in one scope cannot be
>>> modified in a parent scope.
>> That's fine - what was unintuitive to me was that something created
>> in one scope cannot be referred to in that same scope. i.e. you can
>> create a piecewise using a[...]=... but cannot then refer to a.
   Ian Foster, Director, Computation Institute
Argonne National Laboratory & University of Chicago
Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
      Globus Alliance: www.globus.org.
