[Swift-devel] CPU usage with provider-deef
Ioan Raicu
iraicu at cs.uchicago.edu
Sat Jun 16 09:17:13 CDT 2007
Actually, it was a bug the Falkon provider, there was a tight polling
loop on a task queue even if it was empty... it got fixed with one line
of code :) its now running the CPU relatively idle for Nika's workflow
which doesn't require high throughputs.
Thanks Yong for fixing it!
Ioan
Ben Clifford wrote:
> It was running something like 68 jobs in 15 minutes. Kinda scary if each
> of those jobs needs 15 cpu.seconds on the submit side.
> On Sat, 16 Jun 2007, Mihael Hategan wrote:
>> That can either be good or bad. If the CPU is used doing meaningful
>> stuff, then it's good. In other words, I'm guessing that the job
>> throughput is also higher with Falkon.
>> Mihael
>> On Fri, 2007-06-15 at 16:48 +0000, Ben Clifford wrote:
>>> Yesterday, I was playing a bit with Ioan and Nika - they submitted a 68
>>> node / 15 minute workflow through provider-deef & falkon and saw the swift
>>> JVM on the submit node using about 100% CPU; then the same workflow
>>> running through the GT2 GRAM provider rather than provider-deef and falkon
>>> appeared to use significantly less.
>>> I wandered off at that point so don't know if any interesting results came
>>> after.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070616/5da49915/attachment.html>
