[Swift-devel] on the semantics of 'array closing'
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 16 04:21:14 CDT 2007
On Fri, 2007-06-15 at 20:55 +0000, Ben Clifford wrote:
> There's a different approach, which is to asay that 'a' is a variable and
> can be assigned to once. Thus assignemnt syntax like a[0]=something
> becomes illegal and we need more functional language constructs.
so is the sequence:
a = 1;
a = 2;
I think this cannot be completely avoided, functional language
constructs or not.
>  So
> instead of writing:
> for e,i in input_array {
>   output_array[i] = p(e);
> we would write:
> output_array = foreach i in input_array {
>   return p(i);
> (its a haskell map in different syntax!)
However, even python features list comprehensions:
output_array = [p(i) for i in input_array]
so we could have both. Karajan already supports streams of this kind:
output_array = stream(parallelFor(i, input_array, p(i))) (give or take
some filters).
Mihael
> That means that, at the language level, output_array is now properly
> single assignment.
> On Fri, 15 Jun 2007, Ian Foster wrote:
> > Hi,
> > For:
> >  a[0] = p()
> >  a[1] = q()
> >  b = s(a)
> > I think there are two distinct issues.
> > a) Determining the size of the array. This could presumably be done by
> > declaring it, e.g.:
> >  a[2] or some similar notion
> >  a[0] = p()
> >  a[1] = q()
> >  b = s(a)
> > or by some "closing" concept.
> > b) Whether or not each element of an array is a separate single-assignment
> > variable. If they are, then the code above should work just fine. If they are
> > not, then we have a couple of behaviors we could define. One would be that
> > b=s(a) blocks until all elements in "a" are defined. The other is that we have
> > a way of "closing" (once again). In that case, we have to define what happens
> > if b=s(a) accesses an element that is not defined.
> > Ian.
> > Ben Clifford wrote:
> > > There is a problem that has been called the 'array closing problem'.
> > > It manifests itself in the tutorial in that certain bits of code that
> > > intuitively can either in a procedure or in the top level can, in practice,
> > > only go in to a procedure.
> > > In that context, I tried to think about better ways to explain/document the
> > > behaviour than "mumble mumble move that code into a procedure".
> > > In Swift we claim to have 'single assignment variables'.
> > > >From single assignment variables we get our grid job ordering:
> > >   a = p()
> > >   b = s(a)
> > > causes first grid job p to run, and when that has completed, then grid job s
> > > will run.
> > > This is the same as if we had written:
> > >   b = s(a)
> > >   a = p()
> > > The ordering comes from the use of a as an 'output' for p and an 'input' for
> > > s, not from source text ordering.
> > > In that model, its meaningless to assign two different things ta a, like
> > > this:
> > >   a = p()
> > >   b = s(a)
> > >   a = t()
> > > Note that I've omitted the data types from the above. This works in the
> > > implementation for simple types such as a datafile marker type.
> > > What is important is that each variable is either unassigned or has its
> > > single value - whenever we refer to that variable, we can either use the
> > > value it has, or defer evaluation of that expression until the variable has
> > > its value.
> > > Now consider arrays. In the present syntax, arrays can be passed as single
> > > (complex) values to/from procedures, like before:
> > >   a = p()
> > >   b = s(a)
> > > Here a and b are array types.
> > > That's fine. a is assigned to by the first statement, and b is assigned to
> > > by the second statement.
> > > But we also support a different assignment syntax for arrays, that looks
> > > like this:
> > >   a[0] = p()
> > >   a[1] = q()
> > >   b = s(a)
> > > This fails at the moment (specifically, I think the execution engine will
> > > hang).
> > > Why? Because the is no one point at which we assign a value to 'a' - the
> > > assignment is split over multiple statements, which can be in various places
> > > (and inside loops etc).
> > > There is nothing in the implementation that detects that a has been assigned
> > > its value.
> > > So there is this notion in the karajan intermediate code of 'closing an
> > > array'.  This is an assertion made in the object code that all assignments
> > > to pieces of an array have been made - that, in affect, the array has its
> > > value.
> > > The suggested hack/workaround for this is to move the array element
> > > assignments into a procedure:
> > >  (file f[]) z() {
> > >    f[0] = p();
> > >    f[1] - q();
> > >  a = z()
> > >  b = s(a)
> > > This works. (which is sort-of a violation of referential transparency)
> > > It works because Swift implicitly marks arrays returned from compound
> > > procedures as closed (which may or may not be correct).
> > > So in most variable scopes, arrays behave like single-assignment variables,
> > > but each array can have one specific scope in which members can be assigned
> > > to. In that scope, the array cannot be treated as a whole variable.
> > > In the z() example above, that special scope is the body of z(). In the
> > > previous example, that scope is the global scope, and the program is invalid
> > > by the rule above that the array cannot be referred to as a whole in the
> > > same place that its members are individually assigned to.
> > > That's my explanation of what's going on now. I think it matches reality. I
> > > don't like that this is reality, but it is what we have.
> > > Comments appreciated.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
