[Swift-devel] on the semantics of 'array closing'
    Yong Zhao
    yongzh at cs.uchicago.edu
    Fri Jun 15 15:46:21 CDT 2007
P.S.
We can not put a closing statement for 'a' right before
	b = s(a);
as all statements are evaluated in parallel, so that b can wait for a to
close to continue. If we do put it there, then b would proceed without
waiting for a to be generated.
Yong.
On Fri, 15 Jun 2007, Yong Zhao wrote:
> Yes, the case is exactly like you have described. Currently each a[i] is
> closed separately, but the whole array also needs to be closed. For
> instance, if in s, only a[0] and a[1] are accessed, it might go through
> correctly, but if s accesses all elements of a (where it has no idea how
> many there are), the workflow would hang to wait for the array to close.
> Mihael and I talked about closing statement, but it is unclear when it
> should be done since the order of each a[i] being closed is not
> deterministic in parallel execution.
> Yong.
> On Fri, 15 Jun 2007, Ian Foster wrote:
> > Hi,
> > For:
> >   a[0] = p()
> >   a[1] = q()
> >   b = s(a)
> > I think there are two distinct issues.
> > a) Determining the size of the array. This could presumably be done by
> > declaring it, e.g.:
> >   a[2] or some similar notion
> >   a[0] = p()
> >   a[1] = q()
> >   b = s(a)
> > or by some "closing" concept.
> > b) Whether or not each element of an array is a separate
> > single-assignment variable. If they are, then the code above should work
> > just fine. If they are not, then we have a couple of behaviors we could
> > define. One would be that b=s(a) blocks until all elements in "a" are
> > defined. The other is that we have a way of "closing" (once again). In
> > that case, we have to define what happens if b=s(a) accesses an element
> > that is not defined.
> > Ian.
> > Ben Clifford wrote:
> > > There is a problem that has been called the 'array closing problem'.
> > > It manifests itself in the tutorial in that certain bits of code that
> > > intuitively can either in a procedure or in the top level can, in
> > > practice, only go in to a procedure.
> > > In that context, I tried to think about better ways to explain/document
> > > the behaviour than "mumble mumble move that code into a procedure".
> > > In Swift we claim to have 'single assignment variables'.
> > > >From single assignment variables we get our grid job ordering:
> > >   a = p()
> > >   b = s(a)
> > > causes first grid job p to run, and when that has completed, then grid job
> > > s will run.
> > > This is the same as if we had written:
> > >   b = s(a)
> > >   a = p()
> > > The ordering comes from the use of a as an 'output' for p and an 'input'
> > > for s, not from source text ordering.
> > > In that model, its meaningless to assign two different things ta a, like
> > > this:
> > >   a = p()
> > >   b = s(a)
> > >   a = t()
> > > Note that I've omitted the data types from the above. This works in the
> > > implementation for simple types such as a datafile marker type.
> > > What is important is that each variable is either unassigned or has its
> > > single value - whenever we refer to that variable, we can either use the
> > > value it has, or defer evaluation of that expression until the variable
> > > has its value.
> > > Now consider arrays. In the present syntax, arrays can be passed as
> > > single (complex) values to/from procedures, like before:
> > >   a = p()
> > >   b = s(a)
> > > Here a and b are array types.
> > > That's fine. a is assigned to by the first statement, and b is assigned to
> > > by the second statement.
> > > But we also support a different assignment syntax for arrays, that looks
> > > like this:
> > >   a[0] = p()
> > >   a[1] = q()
> > >   b = s(a)
> > > This fails at the moment (specifically, I think the execution engine will
> > > hang).
> > > Why? Because the is no one point at which we assign a value to 'a' - the
> > > assignment is split over multiple statements, which can be in various
> > > places (and inside loops etc).
> > > There is nothing in the implementation that detects that a has been
> > > assigned its value.
> > > So there is this notion in the karajan intermediate code of 'closing an
> > > array'.  This is an assertion made in the object code that all assignments
> > > to pieces of an array have been made - that, in affect, the array has its
> > > value.
> > > The suggested hack/workaround for this is to move the array element
> > > assignments into a procedure:
> > >  (file f[]) z() {
> > >    f[0] = p();
> > >    f[1] - q();
> > >  a = z()
> > >  b = s(a)
> > > This works. (which is sort-of a violation of referential transparency)
> > > It works because Swift implicitly marks arrays returned from compound
> > > procedures as closed (which may or may not be correct).
> > > So in most variable scopes, arrays behave like single-assignment
> > > variables, but each array can have one specific scope in which members can
> > > be assigned to. In that scope, the array cannot be treated as a whole
> > > variable.
> > > In the z() example above, that special scope is the body of z(). In the
> > > previous example, that scope is the global scope, and the program is
> > > invalid by the rule above that the array cannot be referred to as a whole
> > > in the same place that its members are individually assigned to.
> > > That's my explanation of what's going on now. I think it matches reality.
> > > I don't like that this is reality, but it is what we have.
> > > Comments appreciated.
> >    Ian Foster, Director, Computation Institute
> > Argonne National Laboratory & University of Chicago
> > Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
> > Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
> > Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
> >       Globus Alliance: www.globus.org.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
