[Swift-devel] Re: GRAM and Swift discussion this week?
    Mike Wilde
    wilde at mcs.anl.gov
    Tue Jun 12 12:32:22 CDT 2007
Hi all,
Were we still planning to meet tomorrow at Argonne?
Can we postpone this till Thu?  nd what time would be good?
Ben, where will you be Thu?
Mike
Stuart Martin wrote, On 5/22/2007 2:41 PM:
> On May 22, 2007, at May 22, 2:22 PM, Ben Clifford wrote:
>> On Tue, 22 May 2007, Stuart Martin wrote:
>>> On May 22, 2007, at May 22, 1:43 PM, Ben Clifford wrote:
>>>> On Tue, 22 May 2007, Ian Foster wrote:
>>>>> Are there WS-GRAM issues that are causing problems for Swift?
>>>> No one uses WS-GRAM with Swift, so we aren't really uncovering issus
>>>> there.
>>> Why not?  What are you using?  GRAM2?  local executions?  Other
>>> services?
>> for the high end stuff, Swift submits jobs to Falkon. Falkon, I think,
>> uses WS-GRAM to start up its own workers, but that startup part of Falkon
>> not Swift.
>> For low end stuff, the two providers that I think people use much are
>> local exec and GRAM2.
>> Local exec is not in the space that GRAM is addressing, so ignore.
> Agreed.  Just trying to learn what people are doing.
>> The GRAM2 vs GRAM4 question pretty much comes down to the fact that
>> people
>> in production (at least as far as I encounter them) tend to use GRAM2
>> rather than GRAM4 and so Swift tends to get used that way too -
>> there's no
>> real motivation to push people to use a different submission system than
>> what they're used to, and one thing we decided within our group is
>> that we
>> would concentrate on being very application focused (after we had spent
>> rather a long time pontificating and debating). GRAM2 -> GRAM4 doesn't
>> provide enough incentive (in the way that a GRAM2 -> Falkon change does)
>> for our actual apps (for example that Tibi and Nika work on).
> Fair enough.  GRAM4 is deployed on most of TG and OSG now.  It would be
> good to push jobs to GRAM4 when reasonable/possible.  The apps folks
> should not care which service is used.  It should be hidden by Swift.
> Or are the apps folks your working with also dictating what GRAM service
> is deployed/used?
>> At some point, perhaps, GRAM2 will decay or GRAM4 will become
>> tantalising,
>> at which point it would be in the interests of being app-focused to
>> shift.
>> Or we might change our priorities to be less app focused.
> Some are quite happy with GRAM4 in 4.0.3.  We're improving things right
> now to make GRAM4 outperform GRAM2 in most all the important
> benchmarks.  This should be in 4.0.5.  I think things at that point
> become "tantalizing".
Mike Wilde
Computation Institute, University of Chicago
Math & Computer Science Division
Argonne National Laboratory
Argonne, IL   60439    USA
tel 630-252-7497 fax 630-252-1997
