[Swift-devel] loops and strings
Veronika Nefedova
nefedova at mcs.anl.gov
Fri Jul 27 14:39:12 CDT 2007
This proves a bit cumbersome to have this combination of swift and
the wrapper. This array declaration has to be inside another loop,
i.e. depend on the loop variable, yet being generated by shell
script... I am still testing various possibilities. Although
generating the string inside swift would've been much easier.
On Jul 27, 2007, at 2:20 PM, Ian Foster wrote:
> Could you not handle the "cat a set of strings" case via a call to
> a shell script or other program that does this?
> Ian
> Sent via BlackBerry from T-Mobile
> -----Original Message-----
> From: Veronika Nefedova <nefedova at mcs.anl.gov>
> Date: Fri, 27 Jul 2007 11:09:19
> To:Mihael Hategan <hategan at mcs.anl.gov>
> Cc:swift-devel at ci.uchicago.edu
> Subject: Re: [Swift-devel] loops and strings
> I need to 'cat' together an unknown number of strings to form a
> string, thats why I was attempting to do it inside the loop. And even
> if I knew the number of loop cycles (say, its 68) -- are you
> suggesting to do it 'by hand' ?
> Anyway - my main goal is not to create this string, but to map an
> array:
> file whamfiles_$s[] <fixed_array_mapper;files="$wham_string">;
> Do you see a solution here?
> Thanks,
> Nika
> On Jul 27, 2007, at 11:01 AM, Mihael Hategan wrote:
>> wham_string2 = @strcat(wham_string, ", wham");
>> print(wham_string2);
>> Variables are not variables. They are labels that are used to
>> direct the
>> data flow. Loops (in the sense of data looping around the same node -
>> picture this as a data flow graph) make no sense.
>> On Fri, 2007-07-27 at 10:50 -0500, Veronika Nefedova wrote:
>>> So how else then I construct a string in swift ?
>>> On Jul 27, 2007, at 10:46 AM, Mihael Hategan wrote:
>>>> Variables in swift are single assignment. You can't assign to a
>>>> variable
>>>> twice. What, in your opinion, should the error message be instead
>>>> of the
>>>> current one?
>>>> On Fri, 2007-07-27 at 10:22 -0500, Veronika Nefedova wrote:
>>>>> I am not sure if its possible to do string operations inside the
>>>>> loop
>>>>> in swift?
>>>>> I have a versy simple test code that doesn't work no matter what.
>>>>> Obviously, I am missing something.
>>>>> This is the code:
>>>>> file fls[]<filesys_mapper;pattern="*.prt",location=".">;
>>>>> string wham_string = "#";
>>>>> foreach prt_file in fls
>>>>> wham_string = @strcat (wham_string, ", wham");
>>>>> print (wham_string);
>>>>> basically I expect to have this as an output:
>>>>> #,wham,wham,wham,wham,... (its a test code (-;)
>>>>> instead I have these errors:
>>>>> wham_string is already assigned with a value of #
>>>>> vdl:assign @ test.kml, line: 46
>>>>> vdl:mains @ test.kml, line: 39
>>>>> Caused by: java.lang.IllegalArgumentException: wham_string is
>>>>> already
>>>>> at org.griphyn.vdl.mapping.AbstractDataNode.setValue
>>>>> (AbstractDataNode.java:255)
>>>>> at org.griphyn.vdl.karajan.lib.Assign.function
>>>>> (Assign.java:70)
>>>>> <snip>
>>>>> In any case -- if I can't construct the string by using the loop -
>>>>> how else could it be done?
>>>>> I use the constructed string then to map an array (I understand I
>>>>> can't map individual array elements):
>>>>> file whamfiles_$s[]
>>>>> <fixed_array_mapper;files="$wham_string">; //it
>>>>> was in the wrapper script before)
>>>>> Nika
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
