[Swift-devel] numeric type(s) in swift.
Ben Clifford
benc at hawaga.org.uk
Tue Jul 24 17:10:43 CDT 2007
On Tue, 24 Jul 2007, Mihael Hategan wrote:
> One potentially problem-causing change (if broken code makes broken
> assumptions) is that Swift number values are not stored as strings any
> more, but as subclasses of java.lang.Number.
I think(?) that the only code that made assumptions about the number
formats are the numerical operators and code that assumes the toString()
output will be of a particular format when passing as a commandline
parameter.
