[Swift-devel] simple_mapper separators
Ben Clifford
benc at hawaga.org.uk
Tue Jul 24 09:42:36 CDT 2007
I've been poking through simple_mapper to look at the various bugs open on
that code.
There's some special case handling for path component separators (in the
abstractfilemapper superclass) such that the last component separator ends
up being a "." instead of whatever comes from the supplied
FileNameElementMapper (which is "_" in the default case).
See the test in svn
tests/language-behaviour/T077-simplemapper-bug80.swift,
which is also here:
http://www.ci.uchicago.edu/trac/swift/browser/trunk/tests/language-behaviour/T076-simplemapper-bug80.swift?format=raw
This maps a three level array structure to filenames in a fairly
straightforward fashion.
The output files are:
T077-simplemapper-bug80.aleph.out
T077-simplemapper-bug80.beth.out
T077-simplemapper-bug80_subordinate.epsilon.out
T077-simplemapper-bug80_subordinate.sigma.out
T077-simplemapper-bug80_subordinate_moresubordinate.hamza.out
Its a bit surprising/unintuitive that the last separator that comes from
the expression path is a "." rather than a "_" like the other ones, at
least in the presence of a suffix; though I can see circumstances where it
is useful (when the structure fields have the same name as filename
extensions and there is not suffix).
The path of least complexity says that this final separator change
shouldn't happen - its easier to document and easier to explain.
