[Swift-devel] VDS1 transfer executable
Mike Wilde
wilde at mcs.anl.gov
Mon Jul 23 10:40:25 CDT 2007
Im in favor of building on transfer. There is also the newer utility "t2".
Jens Im sure will be delighted to expound on these. As I recall one was better
at some things and the other at others.
For example, I think t2 will retry failing I/Os from am alternate PFN if several
replicas are available. But perhaps transfer does parallel transfers better,
or some such advantage. I need to dive into old email to find the info, but in
the meantime Jens or the manpages can probably explain much.
- Mike
Ben Clifford wrote, On 7/23/2007 10:29 AM:
> none of those seem to be arguments for or against rewriting vs reusing.
> On Mon, 23 Jul 2007, Mihael Hategan wrote:
>> Support, throttling, concurrency control. We seem to be fundamentally
>> changing the way things work, and we do that because we can.
>> On Mon, 2007-07-23 at 15:19 +0000, Ben Clifford wrote:
>>> Given that the VDS1 transfer executable exists and appears to work, there
>>> would need to be some strong argument to not use that as a base (which
>>> there may be, but I don't know of one).
>>>> I think the reimplementation argument is not universally valid. One must
>>>> consider costs vs. benefits.
>>>> On Mon, 2007-07-23 at 15:08 +0000, Ben Clifford wrote:
>>>>> VDS1 has a utility, transfer, which is for use on the worker nodes to
>>>>> stage data in and out.
>>>>> It seems fairly seriously worth considering using that, rather than
>>>>> re-implementing stuff from ground up.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Mike Wilde
Computation Institute, University of Chicago
Math & Computer Science Division
Argonne National Laboratory
Argonne, IL 60439 USA
tel 630-252-7497 fax 630-252-1997
