[Swift-devel] VDS1 transfer executable
Mihael Hategan hategan at mcs.anl.gov
Mon Jul 23 10:39:33 CDT 2007
Also, we should steer away from C code. We're far more efficient with
java (both as programmers and as troubleshooters).
On Mon, 2007-07-23 at 10:28 -0500, Mihael Hategan wrote:
> Support, throttling, concurrency control. We seem to be fundamentally
> changing the way things work, and we do that because we can.
> On Mon, 2007-07-23 at 15:19 +0000, Ben Clifford wrote:
> > Given that the VDS1 transfer executable exists and appears to work, there
> > would need to be some strong argument to not use that as a base (which
> > there may be, but I don't know of one).
> > On Mon, 23 Jul 2007, Mihael Hategan wrote:
> > > I think the reimplementation argument is not universally valid. One must
> > > consider costs vs. benefits.
> > > On Mon, 2007-07-23 at 15:08 +0000, Ben Clifford wrote:
> > > > VDS1 has a utility, transfer, which is for use on the worker nodes to
> > > > stage data in and out.
> > > > It seems fairly seriously worth considering using that, rather than
> > > > re-implementing stuff from ground up.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
