[Swift-devel] [Bug 72] Campaign for scaling wf up to 244 molecules
Ian Foster
foster at mcs.anl.gov
Tue Jul 17 21:39:20 CDT 2007
Ioan:
a) I think this information should be in the bugzilla summary, according
to our processes?
b) Why did it take so long to get all of the workers working?
c) Can we debug using less than O(800) node hours?
Ian.
bugzilla-daemon at mcs.anl.gov wrote:
> http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=72
> ------- Comment #24 from iraicu at cs.uchicago.edu 2007-07-17 16:08 -------
> So the latest MolDyn's 244 mol run also failed... but I think it made it all
> the way to the final few jobs...
> The place where I put all the information about the run is at:
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/
> Here are the graphs:
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/summary_graph_med.jpg
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/task_graph_med.jpg
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/executor_graph_med.jpg
> The Swift log can be found at:
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/logs/swift/MolDyn-244-ja4ya01d6cti1.log
> The Falkon logs are at:
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/logs/falkon/
> The 244 mol run was supposed to have 20497 tasks, broken down as follows:
> 1 1 1
> 1 244 244
> 1 244 244
> 68 244 16592
> 1 244 244
> 11 244 2684
> 1 244 244
> 1 244 244
> 20497
> We had 20495 tasks that exited with an exit code of 0, and 6 tasks that exited
> with an exit code of -3. The worker logs don't show anything on the stdout or
> stderr of the failed jobs. I looked online what an exit code of -3 could mean,
> but didn't find anything.
> Here are the failed 6 tasks:
> Executing task urn:0-9408-1184616132483... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-zqtloeei fe_stdout_m112
> stderr.txt wf_m112 solv_chg_a10_m112_done solv_repu_0.2_0.3_m112.out
> solv_repu_0_0.2_m112.out solv_repu_0.9_1_m112.out solv_disp_m112.out
> solv_chg_m112.out solv_repu_0.6_0.7_m112.out solv_repu_0.5_0.6_m112.out
> solv_repu_0.4_0.5_m112.out solv_repu_0.3_0.4_m112.out
> solv_repu_0.8_0.9_m112.out solv_repu_0.7_0.8_m112.out fe_solv_m112
> fe_stdout_m112 /disks/scratchgpfs1/iraicu/ModLyn/bin/fe.pl --nosite
> --resultonly --wham_outputs wf_m112 --solv_lrc_file solv_chg_a10_m112_done
> --fe_file fe_solv_m112
> Task urn:0-9408-1184616132483 completed with exit code -3 in 238 ms
> Executing task urn:0-9408-1184616133199... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-2rtloeei fe_stdout_m112
> Task urn:0-9408-1184616133199 completed with exit code -3 in 201 ms
> Executing task urn:0-15036-1184616133342... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-5rtloeei fe_stdout_m179
> stderr.txt wf_m179 solv_chg_a10_m179_done solv_repu_0.2_0.3_m179.out
> solv_repu_0_0.2_m179.out solv_repu_0.9_1_m179.out solv_disp_m179.out
> solv_chg_m179.out solv_repu_0.6_0.7_m179.out solv_repu_0.5_0.6_m179.out
> solv_repu_0.4_0.5_m179.out solv_repu_0.3_0.4_m179.out
> solv_repu_0.8_0.9_m179.out solv_repu_0.7_0.8_m179.out fe_solv_m179
> fe_stdout_m179 /disks/scratchgpfs1/iraicu/ModLyn/bin/fe.pl --nosite
> --resultonly --wham_outputs wf_m179 --solv_lrc_file solv_chg_a10_m179_done
> --fe_file fe_solv_m179
> Task urn:0-15036-1184616133342 completed with exit code -3 in 267 ms
> Executing task urn:0-15036-1184616133628... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-9rtloeei fe_stdout_m179
> Task urn:0-15036-1184616133628 completed with exit code -3 in 2368 ms
> Executing task urn:0-15036-1184616133528... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-8rtloeei fe_stdout_m179
> Task urn:0-15036-1184616133528 completed with exit code -3 in 311 ms
> Executing task urn:0-9408-1184616130688... Building executable
> command...Executing: /bin/sh shared/wrapper.sh fepl-9ptloeei fe_stdout_m112
> Task urn:0-9408-1184616130688 completed with exit code -3 in 464 ms
> Both the Falkon logs and the Swift logs agree on the number of submitted tasks,
> number of successful tasks, and number of failed tasks. There were no
> outstanding tasks at the time when the workflow failed. BTW, I checked the
> disk space usage after about an hour that the whole experiment finished, and
> there was plenty of disk space left.
> Yong mentioned that he looked through the output of MolDyn, and there were only
> 242 'fe_solv_*' files, so 2 molecule files were missing... one question for
> Nika, are the 6 failed tasks the same job, resubmitted?
> Nika, can you add anything more to this? Is there anything else to be learned
> from the Swift log, as to why those last few jobs failed? After we have tried
> to figure out what happened, can we resume the workflow, and hopefully finish
> the last few jobs in another run?
> Ioan
Ian Foster, Director, Computation Institute
Argonne National Laboratory & University of Chicago
Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
Tel: +1 630 252 4619. Web: www.ci.uchicago.edu.
Globus Alliance: www.globus.org.
