[Swift-devel] [Bug 83] nested loops hung
bugzilla-daemon at mcs.anl.gov
Sun Jul 15 23:09:53 CDT 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=83
------- Comment #7 from tiberius at mcs.anl.gov 2007-07-15 23:09 -------
The code below also hangs.
On the execution node, I only get a subset of the echo jobs to be executed.
This is not good at all.
I was trying the following patttern:
A set of similar inputs (processData) I need to process through various
procedures (echoA, echoB, echoNone) and I was trying to have a batch job that
processes all the inputs through these procedures. Note that in this case there
are no dependencies between the procedures (echoA,echoB, echoNone).
This has got to be a pretty standard pattern.
type file{};
(file echoAfile) echoA (string sIn){
app{
echo sIn stdout=@filename(echoAfile);
(file echoBfile) echoB (string sIn){
app{
echo sIn stdout=@filename(echoBfile);
(file echoCfile) echoNone(){
app{
echo "NONE" stdout=@filename(echoCfile);
(file aResults[], file bResults[], file noResults) testLoop (string symbols[]){
noResults=echoNone();
foreach s,i in symbols {
aResults[i] = echoA(s);
bResults[i] = echoB(s);
string processData[]=["data-1", "data-2"];
string echoANames = "data-1.A data-2.B";
string echoBNames = "data-2.A data-2.B";
file echoEmpty<"echo.empty">;
file echoA[]<fixed_array_mapper; files=echoANames>;
file echoB[]<fixed_array_mapper; files=echoBNames>;
(echoA, echoB, echoEmpty) = testLoop (processData);
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
