[Swift-devel] [Bug 83] New: nested loops hung
bugzilla-daemon at mcs.anl.gov
Fri Jul 13 13:34:34 CDT 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=83
Summary: nested loops hung
Product: Swift
Version: unspecified
Platform: Macintosh
OS/Version: Mac OS
Status: NEW
Severity: normal
Priority: P2
Component: General
AssignedTo: hategan at mcs.anl.gov
ReportedBy: nefedova at mcs.anl.gov
CC: swift-devel at ci.uchicago.edu
OtherBugsDependingO 72
nThis:
Workflows with nested loops freeze. Specifically, this construct:
foreach f in files{
do_something;
print(a);
foreach s in sfiles{
print(b);
something;
if (a=="blah"){
do_staff;
}else{
do_another_stuff;
} # close foreach s
} # close foreach f
(the full code could be found on terminable in ~nefedova/MolDyn.dtm)
Comments from Mihael:
It freezes because files[] is not used. In a sense. The compiler should tag all
data that is not an lvalue but appears as part of an expression as input data.
Apparently the compiler misses the part where the variable is used by a for
loop.
You can convince swift that files and sfiles are inputs by doing something like
print(files); print(sfiles);. Nonetheless, this should be fixed in the
compiler.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
