[Swift-devel] dot files by default
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Jul  8 23:43:48 CDT 2007
To quote swift -help:
[-pgraph <true|false|<filename>>]
      Whether to generate a provenance graph or not. If a 'true' is
      used, the file name for the graph will be chosen by swift.
This can also be set in swift.properties.
The default is 'true'. The issue is whether to switch the default to
'false'.
On Sun, 2007-07-08 at 23:35 -0500, Tiberiu Stef-Praun wrote:
> Add a command line option: --gengraph=false by default.
> Probably it makes more sense in terms of the cleanness of the output.
> On 7/4/07, Ben Clifford <benc at hawaga.org.uk> wrote:
> > does anyone have preference about whether .dot graphviz files are
> > generated by default or not?
> > I find them a bit annoying in as much as they double the number of run
> > files in my working directories to no immediate benefit.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
