[Swift-devel] Re: Karajan problem?
Mihael Hategan hategan at mcs.anl.gov
Fri Jul 6 13:18:46 CDT 2007
Are you trying to access a file as an array? As in
file x;
x[1]
On Fri, 2007-07-06 at 12:38 -0500, Veronika Nefedova wrote:
> Hi, Mihael:
> I am testing now my new code (with loops and various string
> operations!) but I am getting some Karajan errors. I am wondering if
> you could point me to a possible reason for these errors? I do not
> see any reference to my code so I am not sure where to start looking...
> org.griphyn.vdl.mapping.InvalidPathException: Invalid path (1) for
> type file
> type file
> Caused by: org.griphyn.vdl.mapping.InvalidPathException: Invalid path
> (1) for type file
>          at org.griphyn.vdl.karajan.lib.GetField.function
> (GetField.java:33)
>          at org.griphyn.vdl.karajan.lib.VDLFunction.post
> (VDLFunction.java:58)
>          at org.globus.cog.karajan.workflow.nodes.Sequential.startNext
> (Sequential.java:51)
>          at
> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren
> (Sequential.java:27)
>          at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute
> (FlowContainer.java:63)
>          at org.globus.cog.karajan.workflow.nodes.FlowNode.restart
> (FlowNode.java:239)
>          at org.globus.cog.karajan.workflow.nodes.FlowNode.start
> (FlowNode.java:280)
>          at
> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent
> (FlowNode.java:392)
>          at org.globus.cog.karajan.workflow.nodes.FlowNode.event
> (FlowNode.java:331)
>          at org.globus.cog.karajan.workflow.FlowElementWrapper.event
> (FlowElementWrapper.java:227)
>          at org.globus.cog.karajan.workflow.events.EventBus.send
> (EventBus.java:123)
>          at org.globus.cog.karajan.workflow.events.EventBus.sendHooked
> (EventBus.java:97)
>          at org.globus.cog.karajan.workflow.events.EventWorker.run
> (EventWorker.java:69)
> (1) for type file
>          at org.griphyn.vdl.mapping.AbstractDataNode.getFields
> (AbstractDataNode.java:139)
> (AbstractDataNode.java:114)
> (GetField.java:25)
>          ... 12 more
> Execution failed:
> (1) for type file
> Thanks!
> Nika
