[Swift-devel] mapper syntax
Mihael Hategan hategan at mcs.anl.gov
Tue Jul 3 13:01:47 CDT 2007
On Tue, 2007-07-03 at 23:23 +0530, Ben Clifford wrote:
> The syntax:
>   imagefiles if[]
> <my_mapper;foo=@strcat(filename,blah),otherparm=true,moreparams=false>;
> is rather noisy all on one line.
> A syntax change could be to express the above as:
>   imagefiles if[] map my_mapper {
What if "map" be replaced by some operator (":", "~", "#")?
>     foo = @strcat(filename,blah);
>     otherparam = true;
>     moreparams = false;
The semicolon should not be required after a '}'.
