[Swift-devel] Update on Teraport problems with wavlet workflow
    Ben Clifford
    benc at hawaga.org.uk
    Wed Feb 28 12:17:50 CST 2007
On Wed, 28 Feb 2007, Ben Clifford wrote:
> do you have kickstart records for the jobs that are failing?
if you do, then:
> > Summary/Speculation: bad teraport node causes job to be declared as
> > done even though the execution failed
this speculation can be investigated further by:
finding a job that breaks. finding the node name from the kickstart
record. grepping all the kickstart records to find other kickstart records
for those jobs. looking to see if they all fail, or if some work and some
fail. then report back findings here.
