[Swift-devel] Re: test v0.1rc1
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 27 14:54:42 CST 2007
On Tue, 2007-02-27 at 14:54 -0600, Veronika V. Nefedova wrote:
> It worked! Thank you very much for tracking it down, Mihael.
> Anyway -- a complete MolDyn workflow just finished its first run on
> Teragrid (for 3 molecules only).
Groovy. Can it be pumped up?
> Nika
> At 02:19 PM 2/27/2007, Veronika  V. Nefedova wrote:
> >Thanks, Mihael!
> >I'll try it now
> >Nika
> >At 02:04 PM 2/27/2007, Mihael Hategan wrote:
> >>Try it now. The latest nightly build should contain the fix.
> >>The problem was an inner class having synchronized methods and me
> >>idiotically assuming that they will use the outer class' instance
> >>monitor.
> >>Mihael
> >>On Mon, 2007-02-26 at 22:17 -0600, Veronika V. Nefedova wrote:
> >> > If you give me your vds_home location - I can try to run the workflow and
> >> > see if its working...
> >> > NIka
> >> > At 09:57 PM 2/26/2007, Mihael Hategan wrote:
> >> > >Hmm. I made a change to the code that did not seem to be the cause, but
> >> > >some other, smaller issue and enabled some more debugging in log4j. With
> >> > >this, I've been running the workflow in a loop on wiggum for two hours
> >> > >now, and got nothing yet. I don't know what to make of it.
> >> > >I'll keep running and eventually revert the changes to see if they are
> >> > >the source.
> >> > >Mihael
> >> > >On Mon, 2007-02-26 at 14:47 -0600, Mihael Hategan wrote:
> >> > > > On Mon, 2007-02-26 at 14:46 -0600, Veronika V. Nefedova wrote:
> >> > > > > An additional info: This failure happened on TG with 070219 when
> >> I was
> >> > > > > running 2 molecules at the same time (i.e. two executables at
> >> the same
> >> > > > > time). When I tried to run just one, it failed with the same
> >> > > exitcode, but
> >> > > > > didn't have that handle exception:
> >> > > > Right. This seems like a different problem, and I'm not sure if it's
> >> > > > Swift or some problem with TP or the application. That needs to be
> >> > > > investigated.
> >> > > > > 2007-02-26 14:34:41,986 DEBUG vdl:execute2 Application
> >> exception: Job
> >> > > chrm
> >> > > > > failed with an exit code of 174
> >> > > > >          sys:throw @ vdl-int.k, line: 108
> >> > > > >          vdl:checkexitcode @ vdl-int.k, line: 367
> >> > > > >          vdl:execute2 @ execute-default.k, line: 22
> >> > > > >          vdl:execute @ swift-MolDyn.kml, line: 69
> >> > > > >          charmm @ swift-MolDyn.kml, line: 279
> >> > > > >          vdl:mains @ swift-MolDyn.kml, line: 261
> >> > > > > <here it re-tries it>
> >> > > > > Again, the failure with 070219 happens only on TG, on localhost
> >> (wiggum)
> >> > > > > its working just fine.
> >> > > > > Nika
> >> > > > > At 02:38 PM 2/26/2007, Mihael Hategan wrote:
> >> > > > > >That's fine. Just wanted to be clear that we're talking about
> >> the same
> >> > > > > >error. It's good that it also occurs in 070219, because there
> >> are no
> >> > > > > >recent changes I could remember that could trigger it. It's
> >> also good to
> >> > > > > >know that it may or may not occur, because I know approximately
> >> what
> >> > > > > >class of problem we're dealing with.
> >> > > > > >Mihael
> >> > > > > >On Mon, 2007-02-26 at 14:37 -0600, Veronika V. Nefedova wrote:
> >> > > > > > > Yes, I didn't paste it -- its all in the log. If you'd like
> >> I can
> >> > > send you
> >> > > > > > > the log as an attachment...
> >> > > > > > > Nika
> >> > > > > > > At 02:33 PM 2/26/2007, Mihael Hategan wrote:
> >> > > > > > > >Wait, because I'm missing something. Wasn't the error
> >> supposed to be
> >> > > > > > > >"TaskHandler can only handle unsubmitted tasks"?
> >> > > > > > > >On Mon, 2007-02-26 at 14:26 -0600, Veronika V. Nefedova wrote:
> >> > > > > > > > > And now its getting interesting!
> >> > > > > > > > > I have now the same failure (as below) with 070219 as I
> >> had on
> >> > > > > > localhost
> >> > > > > > > > > with v0.1rc1 *BUT* when running on TG. Failed at the same
> >> > > point (while
> >> > > > > > > > > trying to run the last app in the workflow), with the same
> >> > > exceptions.
> >> > > > > > > > > Strange that 070219 worked on localhost (and still working).
> >> > > > > > > > > The log is on wiggum:
> >> > > > > > > > /sandbox/ydeng/alamines/swift-MolDyn-690y7r1skc8z0.log
> >> > > > > > > > > 2007-02-26 14:10:16,543 INFO  vdl:execute2 Running job
> >> > > > > > chrm-rmnoet7i chrm
> >> > > > > > > > > with arguments [system:solv_m001, title:solv, stitle:m001,
> >> > > > > > > > > rtffile:parm03_gaff_all.rtf,
> >> paramfile:parm03_gaffnb_all.prm,
> >> > > > > > > > > gaff:m001_am1, nwater:400, ligcrd:lyz, rforce:0,
> >> iseed:3131887,
> >> > > > > > rwater:15,
> >> > > > > > > > > nstep:100, minstep:100, skipstep:100, startstep:10000] in
> >> > > > > > > > > swift-MolDyn-690y7r1skc8z0/chrm-rmnoet7i on TG-NCSA
> >> > > > > > > > > 2007-02-26 14:11:18,586 DEBUG vdl:execute2 Application
> >> > > exception:
> >> > > > > > Job chrm
> >> > > > > > > > > <snip>
> >> > > > > > > > > All input files are staged in...
> >> > > > > > > > > Nika
> >> > > > > > > > > At 02:17 PM 2/26/2007, Veronika  V. Nefedova wrote:
> >> > > > > > > > > >You can try to run my application, or look in the logs. I
> >> > > ran it
> >> > > > > > all on
> >> > > > > > > > > >wiggum. The log is:
> >> > > > > > > > > >/sandbox/ydeng/alamines/swift-MolDyn-8q6ygr7cy15c2.log
> >> > > > > > > > > >the dtm file I am running is
> >> > > /sandbox/ydeng/alamines/swift-MolDyn.dtm
> >> > > > > > > > > >Nika
> >> > > > > > > > > >At 01:39 PM 2/26/2007, Mihael Hategan wrote:
> >> > > > > > > > > >>That doesn't sound good. How do I reproduce this?
> >> > > > > > > > > >>Mihael
> >> > > > > > > > > >>On Mon, 2007-02-26 at 13:21 -0600, Veronika V.
> >> Nefedova wrote:
> >> > > > > > > > > >> > The one Ben asked us all to test:
> >> > > > > > > > > >> > >http://www.ci.uchicago.edu/swift/tests/vdsk-0.1rc1.
> >> t ar.gz
> >> > > > > > > > > >> > At 01:15 PM 2/26/2007, Mihael Hategan wrote:
> >> > > > > > > > > >> > >On Mon, 2007-02-26 at 13:05 -0600, Veronika V.
> >> Nefedova
> >> > > wrote:
> >> > > > > > > > > >> > > > When I tried to run my working workflow with a new
> >> > > version, it
> >> > > > > > > > > >> gave me an
> >> > > > > > > > > >> > > > exception:
> >> > > > > > > > > >> > >Which new version?
> >> > > > > > > > > >> > >Mihael
> >> > > > > > > > > >> > > > Warning: Task handler throws exception but does not
> >> > > set status
> >> > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> >> > > > > > > > > >> > > >          at
> >> org.globus.cog.abstraction.impl.common.task.CachingFileOperationTaskHandler.submit(CachingFileOperationTaskHandler.java:20)
> >> > > > > > > > > >> > > >          at
> >> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:78)
> >> > > > > > > > > >> > > >          at java.lang.Thread.run(Thread.java:534)
> >> > > > > > > > > >> > > > [349] wiggum /sandbox/ydeng/alamines > \\
> >> > > > > > > > > >> > > > I do not have this happening with 070219 built.
> >> > > > > > > > > >> > > > Nika
> >> > > > > > > > > >> > > > At 06:12 AM 2/26/2007, Ben Clifford wrote:
> >> > > > > > > > > >> > > > >On Mon, 26 Feb 2007, Ben Clifford wrote:
> >> > > > > > > > > >> > > > > > v0.1rc1 was built at the end of last week.
> >> > > please spend
> >> > > > > > > > some time
> >> > > > > > > > > >> > > testing
> >> > > > > > > > > >> > > > >here's the URL for download:
> >> r c1.t
> >> > > ar.gz
> >> > > > > > > > > >> > > > _______________________________________________
> >> > > > > > > > > >> > > > Swift-devel mailing list
> >> > > > > > > > > >> > > > Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
