[Swift-devel] remote file/directory stuff (bug 22)
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 27 14:39:06 CST 2007
On Tue, 2007-02-27 at 20:37 +0000, Ben Clifford wrote:
> On Tue, 27 Feb 2007, Mihael Hategan wrote:
> > > > If you can make this translate into something like vdl:(in|
> > > > out)appmapping(var, path, dest), preferably after the stagein/stageout
> > > > directives, I can probably make it work.
> > > what are path and dest?
> > > the source form only has a left and a right...
> > l.x.y > "foo.txt"
> > l - var
> > x.y - path
> > "foo.txt" - dest
> oh, ok.
> I think that should be straightforward to implement. I'd be interested if
> yong has comment - he knows the swiftscript->kml layer more intimately
> than I.
You can replicate certain assignments. The ones that translate to
vdl:setfieldvalue. It works in a similar way.
