[Swift-devel] Re: [VDL2-user] GridFTP timeout exception
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb 26 13:55:22 CST 2007
Ip address maybe?
On Mon, 2007-02-26 at 13:53 -0600, Tiberiu Stef-Praun wrote:
> How do I know that a GridFTP client timeout occurs ?
> It seems that my SIDGrid workflow has stopped performing.
> Normally it should process 200 parallel tasks, each of which producess
> 1GB  in 28 files.
> I am testing with 0.1 rc 1, but the same has happened to me before
> (SVn checkout, v0.rc3,etc).
> The workflow freezes after a while (after processing the first round
> of jobs submitted? = I received 16G and that's it). The current
> scenario is me using 3 teragrid sites (UC, Purdue, NCSA), but the same
> behavior (workflow freeze) happened when I ran the workflow on
> teraport only. Since It hang, I was always forced to terminate it, so
> we never had a full SIDGrid run.
> Any suggestions ?
> BTW, the NCSA problem is a non-issue, I solved it.  The only other
> small issue is taking full advantage of all the sites in the
> sites.xml. And the big issue is what I listed above.
> Next I will try running the workflow fully at the UC teragrid site.
> Tibi
> On 2/26/07, Ben Clifford <benc at hawaga.org.uk> wrote:
> > On Mon, 26 Feb 2007, Mihael Hategan wrote:
> > > On Fri, 2007-02-23 at 16:58 +0000, Ben Clifford wrote:
> > > > On Fri, 23 Feb 2007, Mihael Hategan wrote:
> > > > > Since this is non-functional (failing to shut down a GridFTP client
> > > > > that's not in use any more), I think the message could be moved to info,
> > > > > and the stack trace to debug.
> > > > sounds good.
> > > Seems like it was at info for about a month now. I split it however to
> > > only log the exception in debug.
> > ok. I guess this error message came from something like 0rc3 as chad
> > reported it originally I think.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
