[Swift-devel] [Bug 120] New: kickstart transfer errors mask underlying application errors
bugzilla-daemon at mcs.anl.gov
Fri Dec 14 09:07:09 CST 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=120
Summary: kickstart transfer errors mask underlying application
errors
Product: Swift
Version: unspecified
Platform: Macintosh
OS/Version: Mac OS
Status: NEW
Severity: normal
Priority: P2
Component: SwiftScript language
AssignedTo: benc at hawaga.org.uk
ReportedBy: benc at hawaga.org.uk
CC: swift-devel at ci.uchicago.edu
in r1515
with kickstart enabled
when an application error occurs so that no kickstart record is produced (for
example, missing input file)
then:
the reported error on the console is a kickstart record missing error, rather
than the probably more appropriate application exception. the application
exception continues to appear in the log file.
cat started
Failed to transfer kickstart records from
mfd-20071214-1503-6jtdb0e0/kickstart/z/localhostFile not found:
/var/tmp/mfd-20071214-1503-6jtdb0e0/kickstart/z/cat-zkk7rhli-kickstart.xml
task:transfer @ vdl-int.k, line: 326
sys:try @ vdl-int.k, line: 326
vdl:transferkickstartrec @ vdl-int.k, line: 413
sys:set @ vdl-int.k, line: 413
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
