[Swift-devel] dataset marking
Ben Clifford
benc at hawaga.org.uk
Thu Dec 6 16:22:35 CST 2007
The present SwiftScript->karajan compiler contains a bunch of code to do
'dataset marking'.
Its a bit tangled, as the other code has evolved around it, and my
understanding of it is correspondingly tangled. So please speak out if
there is a problem with the following.
The purpose of the dataset marking is to identify which dataset
declarations in a SwiftScript program are inputs (to the whole workflow)
and mark them as such in the compiled code. A dataset is an input if it is
never assigned to; if it is assigned to then it is not an input.
I worked on some code that changes the way that arrays are closed, by
identifying which statements write to a dataset, at compile time.
This information is also what is needed, I think, to do the above
mentioned dataset marking - the same code which finds out that some
statements are writing to a dataset will also find out that some datasets
have no statements at all writing to them.
