[Swift-devel] (no subject)
Mihael Hategan
hategan at mcs.anl.gov
Wed Dec 5 18:09:46 CST 2007
On Wed, 2007-12-05 at 18:05 -0600, Tiberiu Stef-Praun wrote:
> I use swift 0.3 with java 1.5 on one of the virtual machines that I
> use for the Econ project
Hmm. I have a hunch. Thanks.
> Luckily Mike's comment brought some light on why I could not run my
> workflows any more.
> Tibi
> On Dec 5, 2007 5:59 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Wed, 2007-12-05 at 17:54 -0600, Tiberiu Stef-Praun wrote:
> > > Ben, I am getting the same error as Rafaelle, and I can reproduce it
> > > Tell me what version of swift to test, to check whether the problem
> > > has been resolved
> > Actually I'd like to know where your version is installed. When I
> > "fixed" it, I didn't really understand what was happening, so I want to
> > correct that.
> > > Tibi
> > > On Dec 5, 2007 4:04 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> > > > On Wed, 5 Dec 2007, Michael Wilde wrote:
> > > > > The gssapi error is what we've seen before - 0.3 running on Java 1.5.
> > > > > Raphaele is now building trunk which should work. We should post something on
> > > > > this or put out an 0.4, perhaps?
> > > > If a new release will make it better, then it would not be too bad to have
> > > > a 0.4 in the next week or so. I'd like to figure out whether that helps or
> > > > not though (for example, if I build it on my system, will it still break
> > > > for others?). For that, better testing of the release candidate (when it
> > > > appears) should probably happen by people other than me.
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
