[Swift-devel] [Bug 114] need to specify run directory name on	remote site
    bugzilla-daemon at mcs.anl.gov
    Mon Dec  3 15:59:35 CST 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=114
benc at hawaga.org.uk changed:
           What    |Removed                     |Added
             Status|NEW                         |RESOLVED
         Resolution|                            |FIXED
------- Comment #1 from benc at hawaga.org.uk  2007-12-03 15:59 -------
r1504 introduces a command-line parameter -runid that allows this to be set.
Caution should be exercised when using this parameter to ensure an appropriate
degree of uniqueness.
>From the commit log:
Added -runid parameter that specifies the run identifier on the command line,
rather than having it automatically generated. This must be unique for every
invocation of a workflow and is used in several places to keep files from
different executions cleanly separated. By default, a datestamp and random
number are used to generate a run identifier. When using this parameter, care
should be taken to ensure that the run ID remains unique with respect to all
other run IDs that might be used, irrespective of (at least) expected run
location, workflow or user.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are the assignee for the bug, or are watching the assignee.
