[Swift-devel] Cant get Falkon provider connected to Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 30 20:23:30 CDT 2007
On Thu, 2007-08-30 at 20:21 -0500, Mihael Hategan wrote:
> On Thu, 2007-08-30 at 20:09 -0500, Veronika Nefedova wrote:
> > I was commenting on these errors:
> > WARN   - Failed to configure log file name
> > DEBUG  - Booting Falkon
> > If you have this, it means your logging is completely screwed up (no
> > log file). It could be fixed in log4j.properties.
> Yeah. The build system cannot very well cope with log4j.properties when
> multiple builds are done. We should probably make provider-deef build as
> a dependency from the start.
Or I should fix the build system.
> > On Aug 30, 2007, at 8:02 PM, Mihael Hategan wrote:
> > > On Thu, 2007-08-30 at 19:44 -0500, Veronika Nefedova wrote:
> > >> You need to fix log4j.properties, I had the same problem some time
> > >> ago. SVN update somehow messes it up.
> > > Irrespective of how logging is set up. When I run, seemingly the same
> > > thing as Mike, it works and it finds the deef provider.
> > > So the problem of finding deef is probably not in the build, but in
> > > something else, unless this is nondeterministic. But from what I
> > > understand, Mike repeatedly got this. Or no?
> > > Mihael
> > >> Nika
> > >> On Aug 30, 2007, at 7:35 PM, Mihael Hategan wrote:
> > >>> Hmm. Strange:
> > >>> hategan at tg-viz-login1:~> swift -d -sites.file ./sites.xml
> > >>> -tc.file ./tc.data test.swift
> > >>> hategan at tg-viz-login1:~> which swift
> > >>> /home/wilde/swift1139f/vdsk-0.2-dev/bin/swift
> > >>> Mihael
> > >>> On Thu, 2007-08-30 at 18:47 -0500, Michael Wilde wrote:
> > >>>> I'm using trunk (release 1139) and getting the following error
> > >>>> when I
> > >>>> run swift:
> > >>>> Execution failed:
> > >>>>          No security context can be found or created for service
> > >>>> (provider deef): No 'deef' provider or alias found. Available
> > >>>> providers: [gt2ft, gsiftp, condor, pbs, ssh, gt4ft, cobalt, local,
> > >>>> dcache, gt4, gsiftp-old, http, gt2, ftp, webdav]. Aliases:
> > >>>> local <-> file; pbs <-> pbslocal; gsiftp-old <-> gridftp-old;
> > >>>> gsiftp <->
> > >>>> gridftp; cobalt <-> cobaltlocal; gt4 <-> gt3.9.5, gt4
> > >>>> .0.2, gt4.0.1, gt4.0.0;
> > >>>> I did what I think was a clean Swift build (ant dist after clean
> > >>>> and
> > >>>> distclean); then from the modules/provider-deef dir did a ant
> > >>>> distclean
> > >>>> and ant dist pointing to my swift vdsk dir that was built in the
> > >>>> prior
> > >>>> step).
> > >>>> I have a cog-provider-deef-1.0.jar file in the lib dir of my dist,
> > >>>> and
> > >>>> my libexec/vds-sc.k file has:
> > >>>>                          element(execution, [provider, url]
> > >>>>                                  service(type="execution",
> > >>>> provider=provider, url=url)
> > >>>> which should match the pool entry in my sites.xml:
> > >>>> <pool handle="UC" sysinfo="INTEL32::LINUX">
> > >>>>      <gridftp url="gsiftp://tg-gridftp.uc.teragrid.org"
> > >>>> storage="/home/wilde/swift/tmp/UC" major="2" minor="2" />
> > >>>>      <jobmanager universe="vanilla"
> > >>>> url="tg-grid.uc.teragrid.org/jobmanager-pbs" major="2" minor="2"/>
> > >>>>      <workdirectory>/home/wilde/swift/tmp/UC</workdirectory>
> > >>>> </pool>
> > >>>> Does anyone know what I missed to messed up here in wiring things
> > >>>> together?
> > >>>> Ive asked Ioan, but he's stumped because this is on the swift
> > >>>> provider
> > >>>> side of things.
> > >>>> Thanks,
> > >>>> Mike
> > >>>> _______________________________________________
> > >>>> Swift-devel mailing list
> > >>>> Swift-devel at ci.uchicago.edu
> > >>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
