[Swift-devel] Re: [Swift-user] Resending: I/O errors in swift script
Michael Wilde wilde at mcs.anl.gov
Thu Aug 30 12:22:10 CDT 2007
Following up on this, Mihael, you said:
 >> 2. Exit code != 0. Looks like some issues with R.
I dont see where in the logs you observed that the jobs were failing. I
think that would have tipped me off earlier that I have an app problem.
I must be looking in the wrong place.  I redirected stdout and stderr
into a file, starting swift like this:
$ swift -debug awf2.swift >swift.out 2>&1 &
from which I get the following logs when all is done:
$ wc -l *log *out
       1 awf2-rm4p72i7lp0r0.0.rlog
    1322 awf2-rm4p72i7lp0r0.log
       1 swift.log
    1400 swift.out
    2724 total
The awf2*.log file seems to be more or less a timestamped version of
stdout/err. (Interesting to note where the extra lines are going that
are in swift.out but not in awf2*.log, though. )
In the .log file I see the text that Ive excerpted below. I think the
following impovements could be made and wonder if you agree:
- Clearly show job exit code (I still dont see this)
- Use mnemonic codes for task types (rather than 1,2...)
- for the logs, map task URNs to simple integers;
   display the mapping up front
- Mike
2007-08-29 18:23:53,895 INFO  vdl:dostagein Staged in pc1.pcap to
awf2-rm4p72i7lp0r0/shared/ on UC
2007-08-29 18:23:53,896 INFO  vdl:execute2 Running job angle4-h2fjbhgi
angle4 with arguments [pc1.pcap,
of-75398839-775c-40ac-bd5c-49275e3269d5-0-1,
cf-a8272a9e-0f23-472f-8b4e-9f7825877a5a-0-1] in
awf2-rm4p72i7lp0r0/angle4-h2fjbhgi on\
  UC
2007-08-29 18:23:54,078 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-3-0-1188429807105) setting status to Submitted
2007-08-29 18:23:54,943 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-2-0-1188429807107) setting status to Submitted
2007-08-29 18:23:55,364 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-6-0-1188429807109) setting status to Submitted
2007-08-29 18:23:55,503 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-3-0-1188429807105) setting status to Active
2007-08-29 18:23:57,057 DEBUG TaskImpl Task(type=2,
identity=urn:0-0-1-0-1-1188429807096) setting status to Completed
2007-08-29 18:23:58,117 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-1-0-1188429807111) setting status to Submitted
2007-08-29 18:24:01,480 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-4-0-1188429807103) setting status to Active
2007-08-29 18:24:06,322 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-2-0-1188429807107) setting status to Active
2007-08-29 18:24:06,727 DEBUG TaskImpl Task(type=1,
identity=urn:0-0-6-0-1188429807109) setting status to Completed
2007-08-29 18:24:06,729 DEBUG TaskImpl Task(type=4,
identity=urn:0-0-6-0-1188429807113) setting status to Active
2007-08-29 18:24:06,734 DEBUG TaskImpl Task(type=4,
identity=urn:0-0-6-0-1188429807113) setting status to Completed
2007-08-29 18:24:06,735 INFO  vdl:execute2 Completed job angle4-h2fjbhgi
cf-a8272a9e-0f23-472f-8b4e-9f7825877a5a-0-1] on UC
2007-08-29 18:24:06,744 INFO  vdl:dostageout Staging out
awf2-rm4p72i7lp0r0/shared/of-75398839-775c-40ac-bd5c-49275e3269d5-0-1 to
file://localhost/of-75398839-775c-40ac-bd5c-49275e3269d5-0-1 from UC
awf2-rm4p72i7lp0r0/shared/cf-a8272a9e-0f23-472f-8b4e-9f7825877a5a-0-1 to
file://localhost/cf-a8272a9e-0f23-472f-8b4e-9f7825877a5a-0-1 from UC
2007-08-29 18:24:06,745 DEBUG TaskImpl Task(type=4,
identity=urn:0-0-6-0-1-1188429807115) setting status to Active
Michael Wilde wrote:
> Great - thanks.  That was indeed the problem: my application script had
> a typo and was trying to run the 32-bit binary regardless what processor
> type it wound up on.  When I last run successfully, I was getting most
> or all i686 machines; this time I was getting ia64 machines.
> I'll try to re-run it w/o debug, and see if the messages need improvement.
> Kickstart would have helped here - would have told me that Im running on
> ia64.
> This is the kind of problem that on a local machine would have been
> recognizable instantly but on a remote machine through swift, karajan,
> globus and PBS is a much greater challenge to diagnose.  We should think
> in terms of how to make that long pipeline to the remote execution
> environment much more transparent to the user.
> Think: "what would I see if I ran this locally" and "how do I bring that
> environment to the swift user"?
> Also noted that:
> - the retry logic here did more harm than good. Maybe we want the
> default for this to be off, especially during debugging.
> - in my latest run, which succeeded, the final job completion was
> excessively delayed. The output files were all back on the submit host,
> 4 of 5 jobs were logged as completed, and the completion of the final
> job seemed to take a few minutes longer.
> I'll work through the error logs more closely and file an enhancement
> request in bugz.
> I can batch these for later discussion or bring them as I encounter
> things, whatever people prefer.  I dont want to distract anyone at the
> moment into long discssions on these; I'll organize them into bug
> reports and enhancement requests and file for discussion when we next
> review priorities.
> Ian was suggesting that this be soon - now is when we need to pick the
> next features for you to work on, Ben and Mihael.  Maybe a review of
> bugs and requests next week, which can be started by email discussion,
> and we'll note which topics needs voice or f2f discussion.
> - Mike
> Mihael Hategan wrote:
>> Ok. You have a bunch of errors, mainly of two types:
>> 1. Missing output file (we should add a rule in error.properties to make
>> that verbose message a little more readable). This may be because the
>> application didn't run or because the filesystem is broken. Right now an
>> exit code file is produced by the wrapper only if the exit code of the
>> application is not 0. This does not allow telling between the
>> application having completed successfully or the filesystem being
>> broken. I believe that a stamp file should also be created by the
>> wrapper in order to distinguish between the two. The reason for the
>> stamp file instead of always having an exit code file is that it is more
>> efficient to check the existence of a file than to stage it out and look
>> at its contents.
>> Mihael
>> On Thu, 2007-08-30 at 08:31 -0500, Michael Wilde wrote:
>>> Resending this after changing list to take larger attachments.
>>> Previous message seems to have gotten lost (I musta pressed the wrong
>>> button in the list manager?)
>>> I'm progressing on the angle runs. Previous errors were due to problems
>>> with svn update, and then apparently needing ant clean and distclean.
>>> Now I'm executing but getting I/O errors.  Ive attached all the logs and
>>> output from this run.
>>> My result files are coming back zero-length and Im seeing I/O errors in
>>> the logs (eg, in swift.out):
>>> Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to
>>> SubmittedTask(type=2, identity=urn:0-0-6-0-1-1188429807121) setting
>>> status to Active
>>> Active
>>> Failed Exception in getFile
>>> My suspcion is that the app is failing and not proucing an expected
>>> output file.  Perhaps theres a clean error in the log that says this but
>>> I havent found it yet.  I think I saw error #500's from gridftp in
>>> the log.
>>> While I debug further, if anyone sees a different or obvious cause, I'd
>>> appreciate your eyeballs on it.
>>> Thanks,
>>> Mike
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
