[Swift-devel] Re: 244 MolDyn run was successful!
Ioan Raicu iraicu at cs.uchicago.edu
Mon Aug 27 13:19:31 CDT 2007
Yes it is, it is VERY different!
With GRAM/PBS, although the failed job only takes 10ms to fail, there is
about a 1 sec overhead to submit the job and get the error code.  In
Falkon, the overhead is about 20ms.  Also, in the time that the 1 node
was faulty (~30 sec), Falkon can submit and return about 1000 failed
tasks, while GRAM/PBS could only do about 15~30 failed jobs.  The fact
that Falkon's submit/execute throughput is 2 orders of magnitude higher
than GRAM/PBS is what makes is different, and hence needs to be handled
different.
Ioan
Ben Clifford wrote:
> On Mon, 27 Aug 2007, Ioan Raicu wrote:
>> On a similar note, IMO, the heuristic in Karajan should be modified to take
>> into account the task execution time of the failed or successful task, and not
>> just the number of tasks.  This would ensure that Swift is not throttling task
>> submission to Falkon when there are 1000s of successful tasks that take on the
>> order of 100s of second to complete, yet there are also 1000s of failed tasks
>> that are only 10 ms long.  This is exactly the case with MolDyn, when we get a
>> bad node in a bunch of 100s of nodes, which ends up throttling the number of
>> active and running tasks to about 100, regardless of the number of processors
>> Falkon has.
> Is that different from when submitting to PBS or GRAM where there are
> 1000s of successful tasks taking 100s of seconds to complete but with
> 1000s of failed tasks that are only 10ms long?
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070827/3f27093d/attachment.html>
