[Swift-devel] Re: 244 MolDyn run was successful!
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Aug 27 12:30:20 CDT 2007
I will look at the Falkon scheduler to what I can do to either throttle
or blacklist task dispatches to bad nodes.
On a similar note, IMO, the heuristic in Karajan should be modified to
take into account the task execution time of the failed or successful
task, and not just the number of tasks.  This would ensure that Swift is
not throttling task submission to Falkon when there are 1000s of
successful tasks that take on the order of 100s of second to complete,
yet there are also 1000s of failed tasks that are only 10 ms long.  This
is exactly the case with MolDyn, when we get a bad node in a bunch of
100s of nodes, which ends up throttling the number of active and running
tasks to about 100, regardless of the number of processors Falkon has.
I also think that when Swift runs in conjunction with Falkon, we should
increase the number of retry attempts Swift is willing to make per task
before giving up.  Currently, it is set to 3, but a higher number of
would be better, considering the low overhead of task submission Falkon has!
I think the combination of these three changes (one from Falkon and
another from Swift) should increase the probability of large workflows
completing on a large number of resources!
Ioan
Veronika Nefedova wrote:
> OK. I looked at the output and it looks like 14 molecules have still
> failed. They all failed due to hardware problems -- I saw nothing
> application-specific in applications logs, all very consistent with
> staled NFS handle that Ioan reported seeing.
> It would be great to be able to stop submitting jobs to 'bad' nodes
> during the run (long term), or to increase the number of retries in
> swift(short term) to enable the whole workflow to go through.
> Nika
> On Aug 13, 2007, at 11:52 PM, Ioan Raicu wrote:
>> Mihael Hategan wrote:
>>> On Mon, 2007-08-13 at 23:07 -0500, Ioan Raicu wrote:
>>>>> small != not at all
>>>> Check out these two graphs, showing the # of active tasks within
>>>> Falkon!  Active tasks = queued+pending+active+done_and_not_delivered.
>>>> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-success-8-10-07/number-of-active-tasks.jpg
>>>> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-success-8-10-07/number-of-active-tasks-zoom.jpg
>>>> Notice that after 3600 some seconds (after all the jobs that failed
>>>> had failed), the # of active tasks in Falkon oscillates between 100
>>>> and 101 active tasks!  The # presented on these graphs are taken from
>>>> the median value per minute (the raw samples were 60 samples per
>>>> minute).  Notice that only at the very end of the experiment, at 30K+
>>>> seconds, the # of active tasks increases to a max of 109 for a brief
>>>> period of time before it drops towards 0 as the workflow completes.  I
>>>> did notice that towards the end of the workflow, the jobs were
>>>> typically shorter, and perhaps that somehow influenced the # of active
>>>> tasks within Falkon...  So, when I said not at all, I was refering to
>>>> this flat line 100~101 active tasks that is shown in these figures!
>>> Then say "it appears (from x and y) that the number of concurrent jobs
>>> does not increase by an observable amount". This is not the same as "the
>>> score does not increase at all".
>> You are playing with words here... the bottom line is that after 19K+
>> jobs and several hours of successful jobs, there was no indication
>> that the heuristic was adapting to the new conditions, in which no
>> jobs were failing!
>>>>>> So you are saying that 19K+ successful jobs was not enough to
>>>>>> counteract the 10K+ failed jobs from the early part of the
>>>>>> experiment?
>>>>> Yep. 19*1/5 = 3.8 < 10.
>>>>>> Can this ratio (1:5) be changed?
>>>>> Yes. The scheduler has two relevant properties: successFactor (currently
>>>>> 0.1) and failureFactor (currently -0.5). The term "factor" is not used
>>>>> formally, since these get added to the current score.
>>>>>> From this experiment, it would seem that the euristic is a slow
>>>>>> learner... maybe you ahve ideas on how to make it more quick to adapt
>>>>>> to changes?
>>>>> That could perhaps be done.
>>>>>>> In the context in which jobs are sent to non-busy workers, the system
>>>>>>> would tend to produce lots of failed jobs if it takes little time
>>>>>>> (compared to the normal run-time of a job) for a bad worker to fail a
>>>>>>> job. This *IS* why the swift scheduler throttles in the beginning: to
>>>>>>> avoid sending a large number of jobs to a resource that is broken.
>>>>>> But not the whole resource is broken...
>>>>> No, just slightly more than 1/3 of it. At least that's how it appears
>>>>> from the outside.
>>>> But a failed job should not be given the same weight as a succesful
>>>> job, in my oppinion.
>>> Nope. I'd punish failures quite harshly. That's because the expected
>>> behavior is for things to work. I would not want a site that fails half
>>> the jobs to be anywhere near keeping a constant score.
>> That is fine, but you have a case (such as this one) in which this is
>> not ideal... how do you propose we adapt to cover this corner case?
>>>>   For example, it seems to me that you are giving the failed jobs 5
>>>> times more weight than succesful jobs, but in reality it should be the
>>>> other way around.  Failed jobs usually will fail quickly (as in the
>>>> case that we have in MolDyn), or they will fail slowly (within the
>>>> lifetime of the resource allocation).  On the other hand, most
>>>> successful jobs will likely take more time to complete that it takes
>>>> for a job to fail (if it fails quickly).   Perhaps instead of
>>>> it should be more like:
>>>> successFactor: +1*(executionTime)
>>>> failureFactor: -1*(failureTime)
>>> That's a very good idea. Biasing score based on run-time (at least when
>>> known). Please note: you should still fix Falkon to not do that thing
>>> it's doing.
>> Its not clear to me this should be done all the time, Falkon needs to
>> know why the failure happened to decide to throttle!
>>>> The 1 could of course be changed with some other weight to give
>>>> preference to successful jobs, or to failed jobs.  With this kind of
>>>> strategy, the problems we are facing with throttling when there are
>>>> large # of short failures wouldn't be happening!  Do you see any
>>>> drawbacks to this approach?
>>> None that are obvious. It's in fact a good thing if the goal is
>>> performance, since it takes execution time into account. I've had manual
>>> "punishments" for connection time-outs because they take a long time to
>>> happen. But this time biasing naturally integrates that kind of stuff.
>>> So thanks.
>>>>>> that is the whole point here...
>>>>> This point comes because you KNOW how things work internally. All Swift
>>>>> sees is 10K failed jobs out of 29K.
>>>>>> anyways, I think this is a valid case that we need to discuss how to
>>>>>> handle, to make the entire Swift+Falkon more robust!
>>>>>> BTW, here is another experiment with MolDyn that shows the throttling
>>>>>> and this heuristic behaving as I would expected!
>>>>>> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed/summary_graph.jpg
>>>>>> Notice the queue lenth (blue line) at around 11K seconds dropped
>>>>>> sharply, but then grew back up.  That sudden drop was many jobs
>>>>>> failing fast on a bad node, and the sudden growth back up was Swift
>>>>>> re-submitting almost the same # of jobs that failed back to Falkon.
>>>>> That failing many jobs fast behavior is not right, regardless of whether
>>>>> Swift can deal with it or not.
>>>> If its a machine error, then it would be best to not fail many jobs
>>>> fast...
>>>> however, if its an app error, you want to fail the tasks as fast as
>>>> possible to fail the entire workflow faster,
>>> But you can't distinguish between the two. The best you can do is assume
>>> that the failure is a linear combination between broken application and
>>> broken node. If it's broken node, rescheduling would do (which does not
>>> happen in your case: jobs keep being sent to the worker that is not
>>> busy, and that's the broken one). If it's a broken application, then the
>>> way to distinguish it from the other one is that after a bunch of
>>> retries on different nodes, it still fails. Notice that different nodes
>>> is essential here.
>> Right, I could try to keep track of statistics on each node, and when
>> failures happen, try to determine if its a system wide failure (all
>> nodes reporting errors), or are the faiures isolated on a single (or
>> small set) node(s)...  I'll have to think about how to do this
>> efficiently!
>>>>  so the app can be fixed and the workflow retried!  For example, say
>>>> you had 1000 tasks (all independent), and had a wrong path set to the
>>>> app... with the current Falkon behaviour, the entire workflow would
>>>> likely fail within some 10~20 seconds of it submitting the first task!
>>>> However, if Falkon does some "smart" throttling when it sees failures,
>>>> its going to take time proportional to the failures to fail the
>>>> workflow!
>>> You're missing the part where all nodes fail the jobs equally, thus not
>>> creating the inequality we're talking about (the ones where broken nodes
>>> get higher chances of getting more jobs).
>> Right, maybe we can use this to distinguish between node failure and
>> app failure!
>>>>   Essentially, I am not a bit fan of throttling task dispatch due to
>>>> failed executions, unless we know why these tasks failed!
>>> Stop putting exclamation marks after every sentence. It diminishes the
>>> meaning of it!
>> So you are going from playing with words to picking on my exclamation! :)
>>> Well, you can't know why these tasks failed. That's the whole problem.
>>> You're dealing with incomplete information and you have to devise
>>> heuristics that get things done efficiently.
>> But Swift might know why it failed, it has a bunch of STDOUT/STDERR
>> that it always captures!  Falkon might capture the same output, but
>> its optional ;(  Could these outputs not be parsed for certain well
>> know errors, and have different exit codes to mean different kinds of
>> errors?
>>>>   Exit codes are not usually enough in general, unless we define our
>>>> own and the app and wrapper scripts generate these particular exit
>>>> codes that Falkon can intercept and interpret reliably!
>>> That would be an improvement, but probably not a universally valid
>>> assumption. So I wouldn't design with only that in mind.
>> But it would be an improvement over what we currently have...
>>>>> Frankly I'd rather Swift not be the part
>>>>> to deal with it because it has to resort to heuristics, whereas Falkon
>>>>> has direct knowledge of which nodes do what.
>>>> That's fine, but I don't think Falkon can do it alone, it needs
>>>> context and failure definition, which I believe only the application
>>>> and Swift could say for certain!
>>> Nope, they can't. Swift does not meddle with semantics of applications.
>>> They're all equally valuable functions.
>>> Now, there's stuff you can do to improve things, I'm guessing. You can
>>> choose not to, and then we can keep having this discussion. There might
>>> be stuff Swift can do, but it's not insight into applications, so you'll
>>> have to ask for something else.
>> Any suggestions?
>> Ioan
>>> Mihael
>>>> Ioan
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
