[Swift-devel] Re: 244 MolDyn run was successful!
Ioan Raicu
iraicu at cs.uchicago.edu
Sun Aug 12 22:46:06 CDT 2007
Mihael Hategan wrote:
> On Sun, 2007-08-12 at 00:22 -0500, Ioan Raicu wrote:
>> Hi,
>> Here is a quick recap of the 244 MolDyn run we made this weekend...
>> I have posted the logs and graphs at:
>> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-success-8-10-07/
>> 11079 failed with a -1.
>> 2 failed with an exit code of 127.
>> Inspecting the logs revealed the infamous stale NFS handle error!
>> A single machine (192.5.198.37) had all the failed tasks (11081
>> tasks); the machine was not completely broken, as it did complete 4
>> tasks successfully, although the completion times were considerably
>> higher than the other machines.
> It seems a bit inefficient that 1/3 of the tasks would go to the one
> machine (out of a fairly large number) that consistently fails tasks.
Only one machine had problems with the GPFS mount. The errors we
happening within the first 10 ms or so, and the communication overhead
was around 20~30 ms, so we are talking about a bad machine that is
failing tasks every 30~40 ms. while other machines that were operating
normally had jobs lasting a few minutes. Now, the GPFS mount errors
came in bursts of some tens of seconds to maybe a minute or two (several
of these), in which it failed all the tasks in a few batches.
>> 20836 tasks finished with an exit code 0.
>> I was expecting 20497 tasks broken down as follows:
>> 1
>> 1
>> 1
>> 1
>> 244
>> 244
>> 1
>> 244
>> 244
>> 68
>> 244
>> 16592
>> 1
>> 244
>> 244
>> 11
>> 244
>> 2684
>> 1
>> 244
>> 244
>> 1
>> 244
>> 244
>> 20497
>> I do not know why there were 339 more tasks than we were expecting.
>> A close look at the summary graph
>> (http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-success-8-10-07/summary_graph-med.jpg), we see that after the large number of failed tasks, the queue length (blue line) quickly went to 0, and then stayed there as Swift was trickling in only about 100 tasks at a time.
>> For the rest of the experiment, only about 100 tasks at a time were
>> ever running. This is not the first time we have seen this, and it
>> seems that is only showing up when there is a bad machine failing many
>> tasks, and essentially Swift doesn't try to resubmit them fast, and
>> the jobs only trickle in thereafter not keeping all the processors
>> busy.
> That's the job throttle set to 10000, multiplied by a score of 0.01
> (after all those failures).
OK, so should we set the job throttle higher, ideally to make sure that
even in the worst case (such as the one we found), it still sends enough
jobs to keep the processors busy? In our case, we should have set it to
25000 to get about 250 concurrent jobs.
>> When we had runs with no bad nodes and no large number of failures,
>> this did not happen, and Swift essentially submitted all independent
>> tasks to Falkon. I know there is a heuristic within Karajan that is
>> probably affecting the submit rate of tasks after the large number of
>> failures happened, but I think it needs to be tuned to recover from
>> large number of failures so in time, it again attempts to send more.
> It does. Unfortunately jobs keep failing.
I don't think that is the case... they failed in a few bunches over a
relatively small amount of time...
> Set the aforementioned
> throttle higher until a better algorithm is stuck in the scheduler. That
> or stop sending jobs to a machine that keeps failing them.
This is not hard to do in Falkon, look at the exit codes of the
application and do some housekeeping around that, but its not all that
clear that this kind of logic should be in Falkon. I am not sure how
easy its going to be to discern between machine failures and other
errors. I believe the reaction within Falkon should be different
between a machine failure and other errors, so its important to discern
between these.
If Falkon is to take some action when a certain machine keeps failing
jobs, what does everyone recommend?
Should it blacklist the machine to never send jobs again to it, should
it just suspend the machine job dispatch for some time, should it
actually retry failed jobs on other nodes, etc...
>> A good analogy is TCP, think of its window size increasing larger and
>> larger, but then a large number of packets get lost, and TCP collapses
>> its window size, but then never recovering from this and remaining
>> with a small window size for the rest of the connection, regardless of
>> the fact that it could again increase the window size until the next
>> round of lost packets...
> Your analogy is incorrect. In this case the score is kept low because
> jobs keep on failing, even after the throttling kicks in.
I would argue against your theory.... the last job (#12794) failed at
3954 seconds into the experiment, yet the last job (#31917) was ended at
30600 seconds. There were no failed jobs in the last 26K+ seconds with
19K+ jobs. Now my question is again, why would the score not improve at
all over this large period of time and jobs, as the throtling seems to
be relatively constant throughout the experiment (after the failed jobs).
Ioan
> Mihael
>> I believe the normal behavior should allow Swift to recover and again
>> submit many tasks to Falkon. If this heuristic cannot be easily
>> tweaked or made to recover from the "window collapse", could we
>> disable it when we are running on Falkon at a single site?
>> BTW, here were the graphs from a previous run when only the last few
>> jobs didn't finish due to a bug in the application code.
>> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/244-mol-failed-7-16-07/
>> In this run, notice that there were no bad nodes that caused many
>> tasks to fail, and Swift submitted many tasks to Falkon, and managed
>> to keep all processors busy!
>> I think we can call the 244-mol MolDyn run a success, both the current
>> run and the previous run from 7-16-07 that almost finished!
>> We need to figure out how to control the job throttling better, and
>> perhaps on how to automatically detect this plaguing problem with
>> "Stale NFS handle", and possibly contain the damage to significantly
>> fewer task failures. I also think that increasing the # of retries
>> from Swift's end should be considered when running over Falkon.
>> Notice that a single worker can fail as many as 1000 tasks per minute,
>> which are many tasks given that when the NFS stale handle shows up,
>> its around for tens of seconds to minutes at a time.
>> BTW, the run we just made consummed about 1556.9 CPU hours (937.7 used
>> and 619.2 wasted) in 8.5 hours. In contrast, the run we made on
>> 7-16-07 which almost finished, but behaved much better since there
>> were no node failures, consumed about 866.4 CPU hours (866.3 used and
>> 0.1 wasted) in 4.18 hours.
>> When Nika comes back from vacation, we can try the real application,
>> which should consume some 16K CPU hours (service units)! She also
>> has her own temporary allocation at ANL/UC now, so we can use that!
>> Ioan
>> Ioan Raicu wrote:
>>> I think the workflow finally completed successfully, but there are
>>> still some oddities in the way the logs look (especially job
>>> throttling, a few hundred more jobs than I was expecting, etc). At
>>> least, we have all the output we needed for every molecule!
>>> I'll write up a summary of what happened, and draw up some nice
>>> graphs, and send it out later today.
>>> Ioan
>>> iraicu at viper:/home/nefedova/alamines> ls fe_* | wc
>>> 488 488 6832
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070812/fcfb99cf/attachment.html>
