[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 15:39:25 CDT 2007
I removed all references of GenericPortal, and placed FalkonStubs in
their place... there are in total 8 FalkonStubs.jar floating around,
they are all the same... perhaps one of you, Mihael or Ben could clean
this up, and make sure that there is only 1 FalkonStubs.jar!
Mihael Hategan wrote:
> You do have both FalkonStubs and GenericPortal jars in the dist. It's a
> guess as to what java will pick first.
> On Thu, 2007-08-09 at 15:28 -0500, Ioan Raicu wrote:
>> OK, it compiled succesfully after I reworked the jar to include
>> directories and files, and not just tow other jars...
>> now on to testing!
>> Ben Clifford wrote:
>>> I suspect the new and updated jar! didn't work but that you old old and
>>> not updated jars around in your install too because you weren't running
>>> distclean enough.
>>> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>>>> Is that a problem?  I can certainly expand the two jar files... but I thought
>>>> this worked in Yong's install, where I got this new and updated jar!
>>>>> Looks like that jar file contains two other jar files instead of
>>>>> directories and class files.
>>>>> On Thu, 2007-08-09 at 14:52 -0500, Ioan Raicu wrote:
>>>>>> OK, updated this to reflect the new name, still no luck, same errors...
>>>>>>> That's because you didn't change the project.properties file. You need
>>>>>>> to edit that and replace GenericPortal.jar with whatever the new thing
>>>>>>> is.
>>>>>>> On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
>>>>>>>> Now i am trying to compile the provider-deef, and I fails...  it seems
>>>>>>>> that its not finding the stubs I just added... I changed the file name
>>>>>>>> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
>>>>>>>> special, like to rebuild the classpath with the new jar name so the
>>>>>>>> build can pick it up?
>>>>>>>> Ioan
>>>>>>>> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
>>>>>>>> Buildfile: build.xml
>>>>>>>> distclean:
>>>>>>>> BUILD SUCCESSFUL
>>>>>>>> Total time: 4 seconds
>>>>>>>> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
>>>>>>>> dist:
>>>>>>>> delete.jar:
>>>>>>>>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
>>>>>>>>    [delete] Deleting:
>>>>>>>> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
>>>>>>>> compile:
>>>>>>>>      [echo] [provider-deef]: COMPILE
>>>>>>>>     [mkdir] Created dir:
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/build
>>>>>>>>     [javac] Compiling 8 source files to
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
>>>>>>>> package org.globus.GenericPortal.stubs.GPService_instance does not
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.*;
>>>>>>>>     [javac] ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
>>>>>>>> package org.globus.GenericPortal.stubs.GPService_instance.service does
>>>>>>>> not exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
>>>>>>>> package org.globus.GenericPortal.stubs.Factory does not exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.Factory.CreateResource;
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.Factory.FactoryPortType;
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
>>>>>>>> package org.globus.GenericPortal.stubs.Factory.service does not exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
>>>>>>>>     [javac]                                                       ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
>>>>>>>> package org.globus.GenericPortal.common does not exist
>>>>>>>>     [javac] import org.globus.GenericPortal.common.Notification;
>>>>>>>>     [javac]                                        ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                       ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.Init;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.DeInit;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>> org.globus.GenericPortal.stubs.GPService_instance.Executable;
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
>>>>>>>> not exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
>>>>>>>>     [javac]                                        ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
>>>>>>>> cannot resolve symbol
>>>>>>>>     [javac] symbol  : class FactoryPortType
>>>>>>>>     [javac] location: class
>>>>>>>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
>>>>>>>>     [javac]     private FactoryPortType gpFactory = null;
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
>>>>>>>>     [javac] symbol  : class Notification
>>>>>>>>     [javac]     private Notification userNot = null;
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
>>>>>>>>     [javac]                                        ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
>>>>>>>> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
>>>>>>>>     [javac]     public NotificationThread(Map tasks, Notification
>>>>>>>> userNot, List completedQueue){
>>>>>>>>     [javac]                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
>>>>>>>>     [javac] symbol  : class Executable
>>>>>>>> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
>>>>>>>>     [javac]     private Executable[] execs = null;
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
>>>>>>>>     [javac] symbol  : class UserJob
>>>>>>>>     [javac]     private UserJob job = null;
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
>>>>>>>>     [javac]     public void setStatus (Executable execs[]) {
>>>>>>>>     [javac]                            ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
>>>>>>>> exist
>>>>>>>>     [javac] import
>>>>>>>>     [javac]                                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
>>>>>>>>     [javac] symbol  : class GPPortType
>>>>>>>>     [javac]     public GPPortType getNextResourcePort() {
>>>>>>>>     [javac]            ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
>>>>>>>>     [javac]     public void submit(Task task, Executable exec) {
>>>>>>>>     [javac]                                   ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
>>>>>>>>     [javac]     public static String getMachNamePort(Notification
>>>>>>>> userNot){
>>>>>>>>     [javac]                                          ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
>>>>>>>>     [javac]     public Executable removeFirstExec() throws
>>>>>>>> NoSuchElementException {
>>>>>>>>     [javac]            ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
>>>>>>>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
>>>>>>>>     [javac]     private GPPortType gGP = null;
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
>>>>>>>> prepareSpecification(JobSpecification spec)
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
>>>>>>>>     [javac]     Executable job = prepareSpecification(spec);
>>>>>>>>     [javac]         ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
>>>>>>>>     [javac]     Executable exec = new Executable();
>>>>>>>>     [javac]         ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]                               ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
>>>>>>>>     [javac] symbol  : class DeInit
>>>>>>>>     [javac]             DeInit deInit = new DeInit();
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]                                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
>>>>>>>>     [javac] symbol  : class DeInitResponse
>>>>>>>>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
>>>>>>>>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
>>>>>>>>     [javac]                              ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
>>>>>>>>     [javac] symbol  : class FactoryServiceAddressingLocator
>>>>>>>>     [javac]         FactoryServiceAddressingLocator factoryLocator =
>>>>>>>> new FactoryServiceAddressingLocator();
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
>>>>>>>>     [javac] symbol  : class CreateResourceResponse
>>>>>>>>     [javac]             CreateResourceResponse createResponse =
>>>>>>>> gpFactory
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
>>>>>>>>     [javac]                 .createResource(new CreateResource());
>>>>>>>>     [javac]                                         ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
>>>>>>>>     [javac] symbol  : class GPServiceAddressingLocator
>>>>>>>>     [javac]             GPServiceAddressingLocator instanceLocator =
>>>>>>>> new GPServiceAddressingLocator();
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
>>>>>>>>     [javac]             GPPortType gGP =
>>>>>>>> instanceLocator.getGPPortTypePort(instanceEPR);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
>>>>>>>>     [javac] symbol  : class Init
>>>>>>>>     [javac]             Init initMsg = new Init();
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]                                    ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
>>>>>>>>     [javac] symbol  : class InitResponse
>>>>>>>>     [javac]             InitResponse ir = gGP.init(initMsg);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
>>>>>>>>     [javac]     return (GPPortType) gptPool.get(next);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
>>>>>>>>     [javac]     return (Executable) execQueue.remove(0);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
>>>>>>>>     [javac]             ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]                                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
>>>>>>>>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>>     [javac]                                   ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
>>>>>>>>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
>>>>>>>>     [javac]                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
>>>>>>>>     [javac]     job = new UserJob();
>>>>>>>>     [javac]                   ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
>>>>>>>>     [javac]                 execs = new Executable[num_execs];
>>>>>>>>     [javac]                                 ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
>>>>>>>>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
>>>>>>>>     [javac]                     ^
>>>>>>>>     [javac]
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
>>>>>>>>     [javac] symbol  : class UserJobResponse
>>>>>>>>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
>>>>>>>>     [javac]                     ^
>>>>>>>>     [javac] Note:
>>>>>>>> uses or overrides a deprecated API.
>>>>>>>>     [javac] Note: Recompile with -deprecation for details.
>>>>>>>>     [javac] 74 errors
>>>>>>>> BUILD FAILED
>>>>>>>> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
>>>>>>>> error occurred while executing this line:
>>>>>>>> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
>>>>>>>> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
>>>>>>>> error output for details.
>>>>>>>> Total time: 23 seconds
>>>>>>>> Ioan Raicu wrote:
>>>>>>>>> Right!
>>>>>>>>>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
>>>>>>>>>>> /home/nefedova/cogl/modules/provider-deef/lib/
>>>>>>>>>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
>>>>>>>>>> FalkonStubs.jar' before you commit.
>>>>>>>>> _______________________________________________
>>>>>>>>> Swift-devel mailing list
>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
