[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 15:28:38 CDT 2007
OK, it compiled succesfully after I reworked the jar to include
directories and files, and not just tow other jars...
now on to testing!
Ben Clifford wrote:
> I suspect the new and updated jar! didn't work but that you old old and
> not updated jars around in your install too because you weren't running
> distclean enough.
> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>> Is that a problem?  I can certainly expand the two jar files... but I thought
>> this worked in Yong's install, where I got this new and updated jar!
>> Mihael Hategan wrote:
>>> Looks like that jar file contains two other jar files instead of
>>> directories and class files.
>>> On Thu, 2007-08-09 at 14:52 -0500, Ioan Raicu wrote:
>>>> OK, updated this to reflect the new name, still no luck, same errors...
>>>>> That's because you didn't change the project.properties file. You need
>>>>> to edit that and replace GenericPortal.jar with whatever the new thing
>>>>> is.
>>>>> On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
>>>>>> Now i am trying to compile the provider-deef, and I fails...  it seems
>>>>>> that its not finding the stubs I just added... I changed the file name
>>>>>> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
>>>>>> special, like to rebuild the classpath with the new jar name so the
>>>>>> build can pick it up?
>>>>>> Ioan
>>>>>> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
>>>>>> Buildfile: build.xml
>>>>>> distclean:
>>>>>> BUILD SUCCESSFUL
>>>>>> Total time: 4 seconds
>>>>>> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
>>>>>> dist:
>>>>>> delete.jar:
>>>>>>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
>>>>>>    [delete] Deleting:
>>>>>> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
>>>>>> compile:
>>>>>>      [echo] [provider-deef]: COMPILE
>>>>>>     [mkdir] Created dir:
>>>>>> /home/nefedova/cogl/modules/provider-deef/build
>>>>>>     [javac] Compiling 8 source files to
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
>>>>>> package org.globus.GenericPortal.stubs.GPService_instance does not
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.*;
>>>>>>     [javac] ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
>>>>>> package org.globus.GenericPortal.stubs.GPService_instance.service does
>>>>>> not exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
>>>>>> package org.globus.GenericPortal.stubs.Factory does not exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.Factory.CreateResource;
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.Factory.FactoryPortType;
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
>>>>>> package org.globus.GenericPortal.stubs.Factory.service does not exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
>>>>>>     [javac]                                                       ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
>>>>>> package org.globus.GenericPortal.common does not exist
>>>>>>     [javac] import org.globus.GenericPortal.common.Notification;
>>>>>>     [javac]                                        ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
>>>>>>     [javac] import
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
>>>>>>     [javac] import
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
>>>>>>     [javac] import
>>>>>>     [javac]                                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
>>>>>>     [javac] import
>>>>>>     [javac]                                                       ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.Init;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.DeInit;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
>>>>>> exist
>>>>>>     [javac] import
>>>>>> org.globus.GenericPortal.stubs.GPService_instance.Executable;
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
>>>>>> not exist
>>>>>>     [javac] import
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
>>>>>>     [javac]                                        ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
>>>>>> cannot resolve symbol
>>>>>>     [javac] symbol  : class FactoryPortType
>>>>>>     [javac] location: class
>>>>>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
>>>>>>     [javac]     private FactoryPortType gpFactory = null;
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
>>>>>>     [javac] symbol  : class Notification
>>>>>>     [javac]     private Notification userNot = null;
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
>>>>>>     [javac]                                        ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
>>>>>> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
>>>>>>     [javac]     public NotificationThread(Map tasks, Notification
>>>>>> userNot, List completedQueue){
>>>>>>     [javac]                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
>>>>>>     [javac] symbol  : class Executable
>>>>>> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
>>>>>>     [javac]     private Executable[] execs = null;
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
>>>>>>     [javac] symbol  : class UserJob
>>>>>>     [javac]     private UserJob job = null;
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
>>>>>>     [javac]     public void setStatus (Executable execs[]) {
>>>>>>     [javac]                            ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
>>>>>> exist
>>>>>>     [javac] import
>>>>>>     [javac]                                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
>>>>>>     [javac] symbol  : class GPPortType
>>>>>>     [javac]     public GPPortType getNextResourcePort() {
>>>>>>     [javac]            ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
>>>>>>     [javac]     public void submit(Task task, Executable exec) {
>>>>>>     [javac]                                   ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
>>>>>>     [javac]     public static String getMachNamePort(Notification
>>>>>> userNot){
>>>>>>     [javac]                                          ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
>>>>>>     [javac]     public Executable removeFirstExec() throws
>>>>>> NoSuchElementException {
>>>>>>     [javac]            ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
>>>>>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
>>>>>>     [javac]     private GPPortType gGP = null;
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
>>>>>> prepareSpecification(JobSpecification spec)
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
>>>>>>     [javac]     Executable job = prepareSpecification(spec);
>>>>>>     [javac]         ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
>>>>>>     [javac]     Executable exec = new Executable();
>>>>>>     [javac]         ^
>>>>>>     [javac]
>>>>>>     [javac]                               ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
>>>>>>     [javac] symbol  : class DeInit
>>>>>>     [javac]             DeInit deInit = new DeInit();
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>>     [javac]                                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
>>>>>>     [javac] symbol  : class DeInitResponse
>>>>>>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
>>>>>>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
>>>>>>     [javac]                              ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
>>>>>>     [javac] symbol  : class FactoryServiceAddressingLocator
>>>>>>     [javac]         FactoryServiceAddressingLocator factoryLocator =
>>>>>> new FactoryServiceAddressingLocator();
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
>>>>>>     [javac] symbol  : class CreateResourceResponse
>>>>>>     [javac]             CreateResourceResponse createResponse =
>>>>>> gpFactory
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
>>>>>>     [javac]                 .createResource(new CreateResource());
>>>>>>     [javac]                                         ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
>>>>>>     [javac] symbol  : class GPServiceAddressingLocator
>>>>>>     [javac]             GPServiceAddressingLocator instanceLocator =
>>>>>> new GPServiceAddressingLocator();
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
>>>>>>     [javac]             GPPortType gGP =
>>>>>> instanceLocator.getGPPortTypePort(instanceEPR);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
>>>>>>     [javac] symbol  : class Init
>>>>>>     [javac]             Init initMsg = new Init();
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>>     [javac]                                    ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
>>>>>>     [javac] symbol  : class InitResponse
>>>>>>     [javac]             InitResponse ir = gGP.init(initMsg);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
>>>>>>     [javac]     return (GPPortType) gptPool.get(next);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
>>>>>>     [javac]     return (Executable) execQueue.remove(0);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
>>>>>>     [javac]             ^
>>>>>>     [javac]
>>>>>>     [javac]                                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
>>>>>>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>>     [javac]                                   ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
>>>>>>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
>>>>>>     [javac]                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
>>>>>>     [javac]     job = new UserJob();
>>>>>>     [javac]                   ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
>>>>>>     [javac]                 execs = new Executable[num_execs];
>>>>>>     [javac]                                 ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
>>>>>>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
>>>>>>     [javac]                     ^
>>>>>>     [javac]
>>>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
>>>>>>     [javac] symbol  : class UserJobResponse
>>>>>>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
>>>>>>     [javac]                     ^
>>>>>>     [javac] Note:
>>>>>> uses or overrides a deprecated API.
>>>>>>     [javac] Note: Recompile with -deprecation for details.
>>>>>>     [javac] 74 errors
>>>>>> BUILD FAILED
>>>>>> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
>>>>>> error occurred while executing this line:
>>>>>> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
>>>>>> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
>>>>>> error output for details.
>>>>>> Total time: 23 seconds
>>>>>> Ioan Raicu wrote:
>>>>>>> Right!
>>>>>>>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
>>>>>>>>> /home/nefedova/cogl/modules/provider-deef/lib/
>>>>>>>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
>>>>>>>> FalkonStubs.jar' before you commit.
>>>>>>> _______________________________________________
>>>>>>> Swift-devel mailing list
>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
