[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 13:54:17 CDT 2007
a trimmed version of ls -R from viper:/home/nefedova/cogl/modules
directory, yielded...
./karajan/dist/karajan-0.35/lib:
GenericPortal.jar
./vdsk/dist/oldstuff/vdsk-0.1-dev/lib:
GenericPortal.jar
./vdsk/dist/oldstuff/vdsk-1.0:
GenericPortal.jar
./vdsk/dist/oldstuff/vdsk-1.0/lib:
GenericPortal.jar
./vdsk/dist/vdsk-0.2-dev/lib:
GenericPortal.jar
Now, I renamed the jar to FalkonStubs.jar and it can be found in
/home/nefedova/cogl/modules/provider-deef/lib/
Is it safe to assume that I can remove all the GenericPortal.jar... when
I deploy the provider-deef, will it automatically copy the new
FalkonStubs.jar to the installed Swift lib directory?
Ioan
Ben Clifford wrote:
> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>> I can clean them up... as I suppose there should only be a single instance of
>> these stubs, in a lib directory!  Where should this master jar be, in which
>> lib directory?
> in the SVN, ideally only one copy of any piece of code. I think the right
> place is https://svn.ci.uchicago.edu/svn/vdl2/provider-deef/lib
> That's the only place I see GenericPortal.jar in the provider-deef and
> swift SVN trees.  Do you see elsewhere? if so where?
