[Swift-devel] Q about MolDyn
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Wed Aug  8 15:45:52 CDT 2007
nope, its a 244-mol workflow.
I have no errors or exceptions in the log.
nefedova at viper:~/alamines> grep "Completed job" MolDyn-244-loops-
p2p6vy21s5fj0.log | wc
     247    6411   45191
nefedova at viper:~/alamines> grep "Running job" MolDyn-244-loops-
     489   13923  149727
nefedova at viper:~/alamines> grep "xception"  MolDyn-244-loops-
       0       0       0
So I guess something else is wrong here?
Nika
On Aug 8, 2007, at 3:35 PM, Ioan Raicu wrote:
> Did you try just a small workflow to test? It looks to be idle
> 13014.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> 13015.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> 13016.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> 13017.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> 13018.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> 13019.996 0 1 42 188 188 0 0 0.0 0.0 0.0 0.0 489.0 0.0
> with 489 jobs completed... is this normal?
> Veronika Nefedova wrote:
>> anyway - I fixed the log4j.properties file and started the run
>> Nika
>> On Aug 8, 2007, at 2:20 PM, Ioan Raicu wrote:
>>> All my work was related to the deef-provider... I did not touch
>>> anything else!
>>> in the folder
>>> nefedova at viper:~/cogl/modules/provider-deef
>>> I did:
>>> cp yongs_source_files src/org/globus/cog/abstraction/impl/
>>> execution/deef/
>>> svn update
>>> ant distclean
>>> ant -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/
>>> Now why would this screw up your logging or anything else in
>>> Swift?  Unless it screwed something up in the deef-provider
>>> (which was already screwed up prior).  Now, the message "booting
>>> deef" comes from Boot.java.  This file was from SVN, as Mihael
>>> modified it a few days ago, so Yong's Boot.java was not carried
>>> over.  Should I have used the older Boot.java (Yong's version
>>> from July 26th)?  If this is not the issue, and its something
>>> else related to the deef-provider, you can find the old deef-
>>> provider that you had before at:
>>> viper:/home/nefedova/cogl/modules/provider-deef_8-8-07_svn
>>> Ioan
>>> PS: I don't have rights to commit changes to SVN, so if you don't
>>> want me to make any more changes to your Swift install, we can
>>> wait until I get the right to commit my changes so you can see
>>> them and pull them in yourself through SVN.
>>>> the current changes screwed up my logging again...
>>>> Please, do not touch my install --- I'd rather get everything
>>>> from SVN,
>>>> nefedova at viper:~/alamines> swift -tc.file tc-uc.data -sites.file
>>>> sites-uc-64.xml -debug MolDyn-244-loops.swift&
>>>> [1] 10562
>>>> nefedova at viper:~/alamines> WARN   - Failed to configure log file
>>>> name
>>>> DEBUG  - Booting deef
>>>> Nika
>>>> On Aug 8, 2007, at 1:19 PM, Mihael Hategan wrote:
>>>>> On Wed, 2007-08-08 at 13:04 -0500, Ioan Raicu wrote:
>>>>>> Shouldn't we be certain that things work before we commit the
>>>>>> changes?
>>>>> No.
>>>>>>   I thought the commit would take place after we try MolDyn
>>>>>> out and we
>>>>>> see things are back to normal.
>>>>> The whole problem we've seen the past few days was due to the
>>>>> fact that
>>>>> Nika had no clear place to get the code from, so she repeatedly
>>>>> ended up
>>>>> with broken versions. S o  p u t  t h e  c h a n g e s  i n  S
>>>>> V N !
>>>>>> Ioan
>>>>>>> On Wed, 2007-08-08 at 11:59 -0500, Ioan Raicu wrote:
>>>>>>>> OK everyone, I found Yong's version of the provider dated
>>>>>>>> July 26th,
>>>>>>>> much more recent than what was in SVN on June 27th.  I
>>>>>>>> updated Nika's
>>>>>>>> version of the provider (which has been checked out of SVN),
>>>>>>> No. P u t  t h e  c h a n g e s  i n  S V N !
>>>>>>>> and recompiled&deploy!
>>>>>>>>   ant distclean
>>>>>>>> vdsk-0.2-dev/
>>>>>>>> dist
>>>>>>>> I even updated updated some of the logging info to use the
>>>>>>>> logger
>>>>>>>> (some were not using the logger).
>>>>>>>> Nika, Falkon is freshly restarted and ready for another test
>>>>>>>> run!
>>>>>>>> Falkon Factory Service:
>>>>>>>> http://tg-viz-login2.uc.teragrid.org:50020/wsrf/services/
>>>>>>>> GenericPortal/core/WS/GPFactoryService
>>>>>>>> Web Server: http://tg-viz-login2.uc.teragrid.org:51000/
>>>>>>>> index.htm
>>>>>>>> Ioan
>>>>>>>>> Ioan,
>>>>>>>>> It looks like the Falcon (including provider-deef) was put
>>>>>>>>> in SVN on
>>>>>>>>> June 27th. You really were supposed to use the SVN code
>>>>>>>>> from that
>>>>>>>>> point. Sigh. Did you do any changes to viper install after
>>>>>>>>> June
>>>>>>>>> 27th?
>>>>>>>>> Nika
>>>>>>>>> On Aug 7, 2007, at 11:32 AM, Ioan Raicu wrote:
>>>>>>>>>> Could it be that the fixes were done before the original SVN
>>>>>>>>>> checkin?   If not, then at least we know why things aren't
>>>>>>>>>> working.  I bet the latest provider source was in Nika's
>>>>>>>>>> Swift
>>>>>>>>>> install on viper.  Nika, I take it you don't have this
>>>>>>>>>> anymore, as
>>>>>>>>>> SVN updates overwrote this.  Yong, is there any other
>>>>>>>>>> place you
>>>>>>>>>> might have the latest provider source?  If not, I guess we
>>>>>>>>>> need to
>>>>>>>>>> take another look through the provider source to fix the
>>>>>>>>>> issues
>>>>>>>>>> that we knew of...
>>>>>>>>>> Ioan
>>>>>>>>>>> Well, it doesn't look like the falkon provider in SVN has
>>>>>>>>>>> been updated
>>>>>>>>>>> at all in terms of fixing synchronization issues. All
>>>>>>>>>>> commits on
>>>>>>>>>>> provider-deef come from either ben or me:
>>>>>>>>>>> bash-3.1$ svn log
>>>>>>>>>>> r1053 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:49:48
>>>>>>>>>>> -0500 (Fri, 03 Aug
>>>>>>>>>>> 2007) | 1 line
>>>>>>>>>>> removed gt4 stuff and added them as a dependency
>>>>>>>>>>> r1052 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:48:25
>>>>>>>>>>> -0500 (Fri, 03 Aug
>>>>>>>>>>> 2007) | 1 line
>>>>>>>>>>> r1051 | benc at CI.UCHICAGO.EDU | 2007-08-03 14:20:21 -0500
>>>>>>>>>>> (Fri, 03 Aug
>>>>>>>>>>> 2007) | 1 line
>>>>>>>>>>> a very small readme for provider-deef
>>>>>>>>>>> r875 | benc at CI.UCHICAGO.EDU | 2007-06-27 15:00:12 -0500
>>>>>>>>>>> (Wed, 27 Jun
>>>>>>>>>>> 2007) | 1 line
>>>>>>>>>>> remove dist directory form svn
>>>>>>>>>>> r873 | benc at CI.UCHICAGO.EDU | 2007-06-27 10:23:15 -0500
>>>>>>>>>>> (Wed, 27 Jun
>>>>>>>>>>> 2007) | 20 lines
>>>>>>>>>>> provider-deef, the Falkon/cog provider
>>>>>>>>>>> based on source in below message, with .class files deleted
>>>>>>>>>>> Date: Wed, 27 Jun 2007 09:27:23 -0500
>>>>>>>>>>> From: Veronika Nefedova <nefedova at mcs.anl.gov>
>>>>>>>>>>> To: Yong Zhao <yongzh at cs.uchicago.edu>
>>>>>>>>>>> Cc: Ben Clifford <benc at hawaga.org.uk>, Mihael Hategan
>>>>>>>>>>> <hategan at mcs.anl.gov>,
>>>>>>>>>>>     iraicu at cs.uchicago.edu, Ian Foster <foster at mcs.anl.gov>,
>>>>>>>>>>>     Mike Wilde <wilde at mcs.anl.gov>,
>>>>>>>>>>>     Tiberiu Stef-Praun <tiberius at ci.uchicago.edu>
>>>>>>>>>>> Subject: Re: 244 molecule MolDyn run...
>>>>>>>>>>> its on viper.uchicago.edu
>>>>>>>>>>> in : /home/nefedova/cogl/modules/provider-deef/
>>>>>>>>>>> I also tared it up and put in my home on terminable:
>>>>>>>>>>> ~nefedova/cogl.tgz
>>>>>>>>>>> Nika
>>>>>>>>>>> On Tue, 2007-08-07 at 10:01 -0500, Veronika Nefedova wrote:
>>>>>>>>>>>> Mihael, do you have any clues on why this run has
>>>>>>>>>>>> failed? Ioan - my
>>>>>>>>>>>> answers to your questions are below...
>>>>>>>>>>>> On Aug 6, 2007, at 10:28 PM, Ioan Raicu wrote:
>>>>>>>>>>>>> It looks like viper (where Swift is running) is idle,
>>>>>>>>>>>>> and so is tg-
>>>>>>>>>>>>> viz-login2 (where Falkon is running).
>>>>>>>>>>>>> What looks evident to me is that the normal list of
>>>>>>>>>>>>> events is for a
>>>>>>>>>>>>> successful task:
>>>>>>>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "urn:
>>>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989" MolDyn-244-loops-
>>>>>>>>>>>>> zhgo6be8tjhi1.log
>>>>>>>>>>>>> 2007-08-06 19:08:25,121 DEBUG TaskImpl Task(type=1,
>>>>>>>>>>>>> identity=urn:
>>>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Submitted
>>>>>>>>>>>>> 2007-08-06 20:58:17,685 DEBUG NotificationThread
>>>>>>>>>>>>> notification: urn:
>>>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989 0
>>>>>>>>>>>>> 2007-08-06 20:58:17,723 DEBUG TaskImpl Task(type=1,
>>>>>>>>>>>>> identity=urn:
>>>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Completed
>>>>>>>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "setting
>>>>>>>>>>>>> status to
>>>>>>>>>>>>> Submitted" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>>>>  17566  175660 2179412
>>>>>>>>>>>>> "NotificationThread
>>>>>>>>>>>>> notification" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>>>>   7959   55713  785035
>>>>>>>>>>>>> status to
>>>>>>>>>>>>> Completed" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>>>> 190968 1909680 24003796
>>>>>>>>>>>>> Now, 17566 tasks were submitted, 7959 notifiation were
>>>>>>>>>>>>> received
>>>>>>>>>>>>> from Falkon, and 190968 tasks were set to completed...
>>>>>>>>>>>>> Obviously this isn't right.  Falkon only saw 7959
>>>>>>>>>>>>> tasks, so I would
>>>>>>>>>>>>> argue that the # of notifications received is correct.
>>>>>>>>>>>>> The
>>>>>>>>>>>>> submitted # of tasks looks like the # I would have
>>>>>>>>>>>>> expected, but
>>>>>>>>>>>>> all the tasks did not make it to Falkon.  The Falkon
>>>>>>>>>>>>> provider is
>>>>>>>>>>>>> what sits between the change of status to submitted,
>>>>>>>>>>>>> and the
>>>>>>>>>>>>> receipt of the notification, so I would say that is the
>>>>>>>>>>>>> first place
>>>>>>>>>>>>> we need to look for more details... there used to some
>>>>>>>>>>>>> extra debug
>>>>>>>>>>>>> info in the Falkon provider that simply printed all the
>>>>>>>>>>>>> tasks that
>>>>>>>>>>>>> were actually being submitted to Falkon (as opposed to
>>>>>>>>>>>>> just the
>>>>>>>>>>>>> change of status within Karajan).  I don't see those debug
>>>>>>>>>>>>> statements, I bet they got overwritten in the SVN update.
>>>>>>>>>>>>> What about the completed tasks, why are there so many
>>>>>>>>>>>>> (190K)
>>>>>>>>>>>>> completed tasks?  Where did they come from?
>>>>>>>>>>>> "Task" doesn't mean job. It could be just data being
>>>>>>>>>>>> staged in , etc.
>>>>>>>>>>>> The first 2 are important -- (Submitted vs Completed).
>>>>>>>>>>>> Since it
>>>>>>>>>>>> differs, this is the problem...
>>>>>>>>>>>>> Yong, are you keeping up with these emails?  Do you
>>>>>>>>>>>>> still have a
>>>>>>>>>>>>> copy of the latest Falkon provider that you edited just
>>>>>>>>>>>>> before you
>>>>>>>>>>>>> left?  Can you just take a look through there to make
>>>>>>>>>>>>> sure nothing
>>>>>>>>>>>>> has been broken with the SVN updates?  If you don't
>>>>>>>>>>>>> have time for
>>>>>>>>>>>>> this now (considering today was your first day on the
>>>>>>>>>>>>> new job),
>>>>>>>>>>>>> I'll dig through there and see if I can make some sense
>>>>>>>>>>>>> of what is
>>>>>>>>>>>>> happening!
>>>>>>>>>>>>> One last thing, Ben mentioned that the Falkon provider
>>>>>>>>>>>>> you saw in
>>>>>>>>>>>>> Nika's account was different than what was in SVN.
>>>>>>>>>>>>> Ben, did you at
>>>>>>>>>>>>> least look at modification dates?  How old was one as
>>>>>>>>>>>>> opposed to
>>>>>>>>>>>>> the other?  I hope we did not revert back to an older
>>>>>>>>>>>>> version that
>>>>>>>>>>>>> might have had some bug in it....
>>>>>>>>>>>> I had to update to the latest version of provider-deef
>>>>>>>>>>>> from SVN since
>>>>>>>>>>>> without the update nothing worked. The version I am at
>>>>>>>>>>>> now is 1050.
>>>>>>>>>>>> But this is exactly the same version of swift/deef I
>>>>>>>>>>>> used for our
>>>>>>>>>>>> Friday run (which 'worked' from Falcon/Swift point of view)
>>>>>>>>>>>> Nika
>>>>>>>>>>>>> Ioan
>>>>>>>>>>>>>> Well, there are some discrepancies:
>>>>>>>>>>>>>> MolDyn-244-loops-
>>>>>>>>>>>>>>    7959  244749 3241072
>>>>>>>>>>>>>> MolDyn-244-loops-
>>>>>>>>>>>>>>   17207  564648 7949388
>>>>>>>>>>>>>> I.e. almost half of the jobs haven't finished
>>>>>>>>>>>>>> (according to swift)
>>>>>>>>>>>>>> I also have some exceptions:
>>>>>>>>>>>>>> 2007-08-06 19:08:49,378 DEBUG TaskImpl Task(type=2,
>>>>>>>>>>>>>> identity=urn:
>>>>>>>>>>>>>> 0-1-101-2-37-0-0-1186444363341) setting status to
>>>>>>>>>>>>>> Failed Exception
>>>>>>>>>>>>>> in getFile
>>>>>>>>>>>>>> (80 of those):
>>>>>>>>>>>>>> nefedova at viper:~/alamines> grep "ailed" MolDyn-244-loops-
>>>>>>>>>>>>>>      80     880    9705
>>>>>>>>>>>>>> Nika
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
