[Swift-devel] Q about MolDyn
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Wed Aug  8 14:52:55 CDT 2007
anyway - I fixed the log4j.properties file and started the run
Nika
On Aug 8, 2007, at 2:20 PM, Ioan Raicu wrote:
> All my work was related to the deef-provider... I did not touch
> anything else!
> in the folder
> nefedova at viper:~/cogl/modules/provider-deef
> I did:
> cp yongs_source_files src/org/globus/cog/abstraction/impl/execution/
> deef/
> svn update
> ant distclean
> ant -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/
> Now why would this screw up your logging or anything else in
> Swift?  Unless it screwed something up in the deef-provider (which
> was already screwed up prior).  Now, the message "booting deef"
> comes from Boot.java.  This file was from SVN, as Mihael modified
> it a few days ago, so Yong's Boot.java was not carried over.
> Should I have used the older Boot.java (Yong's version from July
> 26th)?  If this is not the issue, and its something else related to
> the deef-provider, you can find the old deef-provider that you had
> before at:
> viper:/home/nefedova/cogl/modules/provider-deef_8-8-07_svn
> Ioan
> PS: I don't have rights to commit changes to SVN, so if you don't
> want me to make any more changes to your Swift install, we can wait
> until I get the right to commit my changes so you can see them and
> pull them in yourself through SVN.
> Veronika Nefedova wrote:
>> the current changes screwed up my logging again...
>> Please, do not touch my install --- I'd rather get everything from
>> SVN,
>> nefedova at viper:~/alamines> swift -tc.file tc-uc.data -sites.file
>> sites-uc-64.xml -debug MolDyn-244-loops.swift&
>> [1] 10562
>> nefedova at viper:~/alamines> WARN   - Failed to configure log file name
>> DEBUG  - Booting deef
>> Nika
>> On Aug 8, 2007, at 1:19 PM, Mihael Hategan wrote:
>>> On Wed, 2007-08-08 at 13:04 -0500, Ioan Raicu wrote:
>>>> Shouldn't we be certain that things work before we commit the
>>>> changes?
>>> No.
>>>>   I thought the commit would take place after we try MolDyn out
>>>> and we
>>>> see things are back to normal.
>>> The whole problem we've seen the past few days was due to the
>>> fact that
>>> Nika had no clear place to get the code from, so she repeatedly
>>> ended up
>>> with broken versions. S o  p u t  t h e  c h a n g e s  i n  S V N !
>>>> Ioan
>>>>> On Wed, 2007-08-08 at 11:59 -0500, Ioan Raicu wrote:
>>>>>> OK everyone, I found Yong's version of the provider dated July
>>>>>> 26th,
>>>>>> much more recent than what was in SVN on June 27th.  I updated
>>>>>> Nika's
>>>>>> version of the provider (which has been checked out of SVN),
>>>>> No. P u t  t h e  c h a n g e s  i n  S V N !
>>>>>> and recompiled&deploy!
>>>>>>   ant distclean
>>>>>> vdsk-0.2-dev/
>>>>>> dist
>>>>>> I even updated updated some of the logging info to use the logger
>>>>>> (some were not using the logger).
>>>>>> Nika, Falkon is freshly restarted and ready for another test run!
>>>>>> Falkon Factory Service:
>>>>>> http://tg-viz-login2.uc.teragrid.org:50020/wsrf/services/
>>>>>> GenericPortal/core/WS/GPFactoryService
>>>>>> Web Server: http://tg-viz-login2.uc.teragrid.org:51000/index.htm
>>>>>> Ioan
>>>>>>> Ioan,
>>>>>>> It looks like the Falcon (including provider-deef) was put in
>>>>>>> SVN on
>>>>>>> June 27th. You really were supposed to use the SVN code from
>>>>>>> that
>>>>>>> point. Sigh. Did you do any changes to viper install after June
>>>>>>> 27th?
>>>>>>> Nika
>>>>>>> On Aug 7, 2007, at 11:32 AM, Ioan Raicu wrote:
>>>>>>>> Could it be that the fixes were done before the original SVN
>>>>>>>> checkin?   If not, then at least we know why things aren't
>>>>>>>> working.  I bet the latest provider source was in Nika's Swift
>>>>>>>> install on viper.  Nika, I take it you don't have this
>>>>>>>> anymore, as
>>>>>>>> SVN updates overwrote this.  Yong, is there any other place you
>>>>>>>> might have the latest provider source?  If not, I guess we
>>>>>>>> need to
>>>>>>>> take another look through the provider source to fix the issues
>>>>>>>> that we knew of...
>>>>>>>> Ioan
>>>>>>>>> Well, it doesn't look like the falkon provider in SVN has
>>>>>>>>> been updated
>>>>>>>>> at all in terms of fixing synchronization issues. All
>>>>>>>>> commits on
>>>>>>>>> provider-deef come from either ben or me:
>>>>>>>>> bash-3.1$ svn log
>>>>>>>>> r1053 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:49:48 -0500
>>>>>>>>> (Fri, 03 Aug
>>>>>>>>> 2007) | 1 line
>>>>>>>>> removed gt4 stuff and added them as a dependency
>>>>>>>>> r1052 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:48:25 -0500
>>>>>>>>> (Fri, 03 Aug
>>>>>>>>> 2007) | 1 line
>>>>>>>>> r1051 | benc at CI.UCHICAGO.EDU | 2007-08-03 14:20:21 -0500
>>>>>>>>> (Fri, 03 Aug
>>>>>>>>> 2007) | 1 line
>>>>>>>>> a very small readme for provider-deef
>>>>>>>>> r875 | benc at CI.UCHICAGO.EDU | 2007-06-27 15:00:12 -0500
>>>>>>>>> (Wed, 27 Jun
>>>>>>>>> 2007) | 1 line
>>>>>>>>> remove dist directory form svn
>>>>>>>>> r873 | benc at CI.UCHICAGO.EDU | 2007-06-27 10:23:15 -0500
>>>>>>>>> (Wed, 27 Jun
>>>>>>>>> 2007) | 20 lines
>>>>>>>>> provider-deef, the Falkon/cog provider
>>>>>>>>> based on source in below message, with .class files deleted
>>>>>>>>> Date: Wed, 27 Jun 2007 09:27:23 -0500
>>>>>>>>> From: Veronika Nefedova <nefedova at mcs.anl.gov>
>>>>>>>>> To: Yong Zhao <yongzh at cs.uchicago.edu>
>>>>>>>>> Cc: Ben Clifford <benc at hawaga.org.uk>, Mihael Hategan
>>>>>>>>> <hategan at mcs.anl.gov>,
>>>>>>>>>     iraicu at cs.uchicago.edu, Ian Foster <foster at mcs.anl.gov>,
>>>>>>>>>     Mike Wilde <wilde at mcs.anl.gov>,
>>>>>>>>>     Tiberiu Stef-Praun <tiberius at ci.uchicago.edu>
>>>>>>>>> Subject: Re: 244 molecule MolDyn run...
>>>>>>>>> its on viper.uchicago.edu
>>>>>>>>> in : /home/nefedova/cogl/modules/provider-deef/
>>>>>>>>> I also tared it up and put in my home on terminable:
>>>>>>>>> ~nefedova/cogl.tgz
>>>>>>>>> Nika
>>>>>>>>> On Tue, 2007-08-07 at 10:01 -0500, Veronika Nefedova wrote:
>>>>>>>>>> Mihael, do you have any clues on why this run has failed?
>>>>>>>>>> Ioan - my
>>>>>>>>>> answers to your questions are below...
>>>>>>>>>> On Aug 6, 2007, at 10:28 PM, Ioan Raicu wrote:
>>>>>>>>>>> It looks like viper (where Swift is running) is idle, and
>>>>>>>>>>> so is tg-
>>>>>>>>>>> viz-login2 (where Falkon is running).
>>>>>>>>>>> What looks evident to me is that the normal list of
>>>>>>>>>>> events is for a
>>>>>>>>>>> successful task:
>>>>>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "urn:
>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989" MolDyn-244-loops-
>>>>>>>>>>> zhgo6be8tjhi1.log
>>>>>>>>>>> 2007-08-06 19:08:25,121 DEBUG TaskImpl Task(type=1,
>>>>>>>>>>> identity=urn:
>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Submitted
>>>>>>>>>>> 2007-08-06 20:58:17,685 DEBUG NotificationThread
>>>>>>>>>>> notification: urn:
>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989 0
>>>>>>>>>>> 2007-08-06 20:58:17,723 DEBUG TaskImpl Task(type=1,
>>>>>>>>>>> identity=urn:
>>>>>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Completed
>>>>>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "setting
>>>>>>>>>>> status to
>>>>>>>>>>> Submitted" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>>  17566  175660 2179412
>>>>>>>>>>> "NotificationThread
>>>>>>>>>>> notification" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>>   7959   55713  785035
>>>>>>>>>>> status to
>>>>>>>>>>> Completed" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>>>>> 190968 1909680 24003796
>>>>>>>>>>> Now, 17566 tasks were submitted, 7959 notifiation were
>>>>>>>>>>> received
>>>>>>>>>>> from Falkon, and 190968 tasks were set to completed...
>>>>>>>>>>> Obviously this isn't right.  Falkon only saw 7959 tasks,
>>>>>>>>>>> so I would
>>>>>>>>>>> argue that the # of notifications received is correct.  The
>>>>>>>>>>> submitted # of tasks looks like the # I would have
>>>>>>>>>>> expected, but
>>>>>>>>>>> all the tasks did not make it to Falkon.  The Falkon
>>>>>>>>>>> provider is
>>>>>>>>>>> what sits between the change of status to submitted, and the
>>>>>>>>>>> receipt of the notification, so I would say that is the
>>>>>>>>>>> first place
>>>>>>>>>>> we need to look for more details... there used to some
>>>>>>>>>>> extra debug
>>>>>>>>>>> info in the Falkon provider that simply printed all the
>>>>>>>>>>> tasks that
>>>>>>>>>>> were actually being submitted to Falkon (as opposed to
>>>>>>>>>>> just the
>>>>>>>>>>> change of status within Karajan).  I don't see those debug
>>>>>>>>>>> statements, I bet they got overwritten in the SVN update.
>>>>>>>>>>> What about the completed tasks, why are there so many (190K)
>>>>>>>>>>> completed tasks?  Where did they come from?
>>>>>>>>>> "Task" doesn't mean job. It could be just data being
>>>>>>>>>> staged in , etc.
>>>>>>>>>> The first 2 are important -- (Submitted vs Completed).
>>>>>>>>>> Since it
>>>>>>>>>> differs, this is the problem...
>>>>>>>>>>> Yong, are you keeping up with these emails?  Do you still
>>>>>>>>>>> have a
>>>>>>>>>>> copy of the latest Falkon provider that you edited just
>>>>>>>>>>> before you
>>>>>>>>>>> left?  Can you just take a look through there to make
>>>>>>>>>>> sure nothing
>>>>>>>>>>> has been broken with the SVN updates?  If you don't have
>>>>>>>>>>> time for
>>>>>>>>>>> this now (considering today was your first day on the new
>>>>>>>>>>> job),
>>>>>>>>>>> I'll dig through there and see if I can make some sense
>>>>>>>>>>> of what is
>>>>>>>>>>> happening!
>>>>>>>>>>> One last thing, Ben mentioned that the Falkon provider
>>>>>>>>>>> you saw in
>>>>>>>>>>> Nika's account was different than what was in SVN.  Ben,
>>>>>>>>>>> did you at
>>>>>>>>>>> least look at modification dates?  How old was one as
>>>>>>>>>>> opposed to
>>>>>>>>>>> the other?  I hope we did not revert back to an older
>>>>>>>>>>> version that
>>>>>>>>>>> might have had some bug in it....
>>>>>>>>>> I had to update to the latest version of provider-deef
>>>>>>>>>> from SVN since
>>>>>>>>>> without the update nothing worked. The version I am at now
>>>>>>>>>> is 1050.
>>>>>>>>>> But this is exactly the same version of swift/deef I used
>>>>>>>>>> for our
>>>>>>>>>> Friday run (which 'worked' from Falcon/Swift point of view)
>>>>>>>>>> Nika
>>>>>>>>>>> Ioan
>>>>>>>>>>>> Well, there are some discrepancies:
>>>>>>>>>>>> nefedova at viper:~/alamines> grep "Completed job"
>>>>>>>>>>>> MolDyn-244-loops-
>>>>>>>>>>>>    7959  244749 3241072
>>>>>>>>>>>> nefedova at viper:~/alamines> grep "Running job" MolDyn-244-
>>>>>>>>>>>> loops-
>>>>>>>>>>>>   17207  564648 7949388
>>>>>>>>>>>> I.e. almost half of the jobs haven't finished (according
>>>>>>>>>>>> to swift)
>>>>>>>>>>>> I also have some exceptions:
>>>>>>>>>>>> 2007-08-06 19:08:49,378 DEBUG TaskImpl Task(type=2,
>>>>>>>>>>>> identity=urn:
>>>>>>>>>>>> 0-1-101-2-37-0-0-1186444363341) setting status to Failed
>>>>>>>>>>>> Exception
>>>>>>>>>>>> in getFile
>>>>>>>>>>>> (80 of those):
>>>>>>>>>>>> nefedova at viper:~/alamines> grep "ailed" MolDyn-244-loops-
>>>>>>>>>>>>      80     880    9705
>>>>>>>>>>>> Nika
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
