[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Wed Aug  8 13:04:16 CDT 2007
Shouldn't we be certain that things work before we commit the changes?
I thought the commit would take place after we try MolDyn out and we see
things are back to normal.
Ioan
Mihael Hategan wrote:
> On Wed, 2007-08-08 at 11:59 -0500, Ioan Raicu wrote:
>> OK everyone, I found Yong's version of the provider dated July 26th,
>> much more recent than what was in SVN on June 27th.  I updated Nika's
>> version of the provider (which has been checked out of SVN),
> No. P u t  t h e  c h a n g e s  i n  S V N !
>>  and recompiled&deploy!
>>   ant distclean
>>   ant -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/
>> dist
>> I even updated updated some of the logging info to use the logger
>> (some were not using the logger).
>> Nika, Falkon is freshly restarted and ready for another test run!
>> Falkon Factory Service:
>> http://tg-viz-login2.uc.teragrid.org:50020/wsrf/services/GenericPortal/core/WS/GPFactoryService
>> Web Server: http://tg-viz-login2.uc.teragrid.org:51000/index.htm
>> Ioan
>> Veronika Nefedova wrote:
>>> Ioan,
>>> It looks like the Falcon (including provider-deef) was put in SVN on
>>> June 27th. You really were supposed to use the SVN code from that
>>> point. Sigh. Did you do any changes to viper install after June
>>> 27th?
>>> Nika
>>> On Aug 7, 2007, at 11:32 AM, Ioan Raicu wrote:
>>>> Could it be that the fixes were done before the original SVN
>>>> checkin?   If not, then at least we know why things aren't
>>>> working.  I bet the latest provider source was in Nika's Swift
>>>> install on viper.  Nika, I take it you don't have this anymore, as
>>>> SVN updates overwrote this.  Yong, is there any other place you
>>>> might have the latest provider source?  If not, I guess we need to
>>>> take another look through the provider source to fix the issues
>>>> that we knew of...
>>>> Ioan
>>>>> Well, it doesn't look like the falkon provider in SVN has been updated
>>>>> at all in terms of fixing synchronization issues. All commits on
>>>>> provider-deef come from either ben or me:
>>>>> bash-3.1$ svn log
>>>>> r1053 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:49:48 -0500 (Fri, 03 Aug
>>>>> 2007) | 1 line
>>>>> removed gt4 stuff and added them as a dependency
>>>>> r1052 | hategan at CI.UCHICAGO.EDU | 2007-08-03 14:48:25 -0500 (Fri, 03 Aug
>>>>> 2007) | 1 line
>>>>> r1051 | benc at CI.UCHICAGO.EDU | 2007-08-03 14:20:21 -0500 (Fri, 03 Aug
>>>>> 2007) | 1 line
>>>>> a very small readme for provider-deef
>>>>> r875 | benc at CI.UCHICAGO.EDU | 2007-06-27 15:00:12 -0500 (Wed, 27 Jun
>>>>> 2007) | 1 line
>>>>> remove dist directory form svn
>>>>> r873 | benc at CI.UCHICAGO.EDU | 2007-06-27 10:23:15 -0500 (Wed, 27 Jun
>>>>> 2007) | 20 lines
>>>>> provider-deef, the Falkon/cog provider
>>>>> based on source in below message, with .class files deleted
>>>>> Date: Wed, 27 Jun 2007 09:27:23 -0500
>>>>> From: Veronika Nefedova <nefedova at mcs.anl.gov>
>>>>> To: Yong Zhao <yongzh at cs.uchicago.edu>
>>>>> Cc: Ben Clifford <benc at hawaga.org.uk>, Mihael Hategan
>>>>> <hategan at mcs.anl.gov>,
>>>>>     iraicu at cs.uchicago.edu, Ian Foster <foster at mcs.anl.gov>,
>>>>>     Mike Wilde <wilde at mcs.anl.gov>,
>>>>>     Tiberiu Stef-Praun <tiberius at ci.uchicago.edu>
>>>>> Subject: Re: 244 molecule MolDyn run...
>>>>> its on viper.uchicago.edu
>>>>> in : /home/nefedova/cogl/modules/provider-deef/
>>>>> I also tared it up and put in my home on terminable: ~nefedova/cogl.tgz
>>>>> Nika
>>>>> On Tue, 2007-08-07 at 10:01 -0500, Veronika Nefedova wrote:
>>>>>> Mihael, do you have any clues on why this run has failed? Ioan - my
>>>>>> answers to your questions are below...
>>>>>> On Aug 6, 2007, at 10:28 PM, Ioan Raicu wrote:
>>>>>>> It looks like viper (where Swift is running) is idle, and so is tg-
>>>>>>> viz-login2 (where Falkon is running).
>>>>>>> What looks evident to me is that the normal list of events is for a
>>>>>>> successful task:
>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "urn:
>>>>>>> 0-1-73-2-31-0-0-1186444341989" MolDyn-244-loops-zhgo6be8tjhi1.log
>>>>>>> 2007-08-06 19:08:25,121 DEBUG TaskImpl Task(type=1, identity=urn:
>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Submitted
>>>>>>> 2007-08-06 20:58:17,685 DEBUG NotificationThread notification: urn:
>>>>>>> 0-1-73-2-31-0-0-1186444341989 0
>>>>>>> 2007-08-06 20:58:17,723 DEBUG TaskImpl Task(type=1, identity=urn:
>>>>>>> 0-1-73-2-31-0-0-1186444341989) setting status to Completed
>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "setting status to
>>>>>>> Submitted" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>  17566  175660 2179412
>>>>>>> iraicu at viper:/home/nefedova/alamines> grep "NotificationThread
>>>>>>> notification" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>>   7959   55713  785035
>>>>>>> Completed" MolDyn-244-loops-zhgo6be8tjhi1.log | wc
>>>>>>> 190968 1909680 24003796
>>>>>>> Now, 17566 tasks were submitted, 7959 notifiation were received
>>>>>>> from Falkon, and 190968 tasks were set to completed...
>>>>>>> Obviously this isn't right.  Falkon only saw 7959 tasks, so I would
>>>>>>> argue that the # of notifications received is correct.  The
>>>>>>> submitted # of tasks looks like the # I would have expected, but
>>>>>>> all the tasks did not make it to Falkon.  The Falkon provider is
>>>>>>> what sits between the change of status to submitted, and the
>>>>>>> receipt of the notification, so I would say that is the first place
>>>>>>> we need to look for more details... there used to some extra debug
>>>>>>> info in the Falkon provider that simply printed all the tasks that
>>>>>>> were actually being submitted to Falkon (as opposed to just the
>>>>>>> change of status within Karajan).  I don't see those debug
>>>>>>> statements, I bet they got overwritten in the SVN update.
>>>>>>> What about the completed tasks, why are there so many (190K)
>>>>>>> completed tasks?  Where did they come from?
>>>>>> "Task" doesn't mean job. It could be just data being staged in , etc.
>>>>>> The first 2 are important -- (Submitted vs Completed). Since it
>>>>>> differs, this is the problem...
>>>>>>> Yong, are you keeping up with these emails?  Do you still have a
>>>>>>> copy of the latest Falkon provider that you edited just before you
>>>>>>> left?  Can you just take a look through there to make sure nothing
>>>>>>> has been broken with the SVN updates?  If you don't have time for
>>>>>>> this now (considering today was your first day on the new job),
>>>>>>> I'll dig through there and see if I can make some sense of what is
>>>>>>> happening!
>>>>>>> One last thing, Ben mentioned that the Falkon provider you saw in
>>>>>>> Nika's account was different than what was in SVN.  Ben, did you at
>>>>>>> least look at modification dates?  How old was one as opposed to
>>>>>>> the other?  I hope we did not revert back to an older version that
>>>>>>> might have had some bug in it....
>>>>>> I had to update to the latest version of provider-deef from SVN since
>>>>>> without the update nothing worked. The version I am at now is 1050.
>>>>>> But this is exactly the same version of swift/deef I used for our
>>>>>> Friday run (which 'worked' from Falcon/Swift point of view)
>>>>>> Nika
>>>>>>> Ioan
>>>>>>>> Well, there are some discrepancies:
>>>>>>>> nefedova at viper:~/alamines> grep "Completed job" MolDyn-244-loops-
>>>>>>>>    7959  244749 3241072
>>>>>>>> nefedova at viper:~/alamines> grep "Running job" MolDyn-244-loops-
>>>>>>>>   17207  564648 7949388
>>>>>>>> I.e. almost half of the jobs haven't finished (according to swift)
>>>>>>>> I also have some exceptions:
>>>>>>>> 2007-08-06 19:08:49,378 DEBUG TaskImpl Task(type=2, identity=urn:
>>>>>>>> 0-1-101-2-37-0-0-1186444363341) setting status to Failed Exception
>>>>>>>> in getFile
>>>>>>>> (80 of those):
>>>>>>>> nefedova at viper:~/alamines> grep "ailed" MolDyn-244-loops-
>>>>>>>>      80     880    9705
>>>>>>>> Nika
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070808/e7bd9ac6/attachment.html>
