[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Tue Aug  7 14:40:36 CDT 2007
Right, ideally... but the debugging process was going so slow, that we
started messing around with Yong and I making changes in Nika's account,
having Nika use my credentials, etc...
I spoke to Yong, and he said he did some tests from his account on viper
just before he left, so there should be a good copy of the provider
there!  I'll look for it and see if I can patch up the Falkon provider!
BTW, I still can't commit changes to SVN...
Ioan
Ben Clifford wrote:
> On Tue, 7 Aug 2007, Veronika Nefedova wrote:
>> Did
>> you do any changes to viper install after June 27th?
> You really shouldn't be letting people mess round with your install - the
> *only* way in which code should land there is by you putting it there, and
> ideally you would only be putting it there from the various SVN locations.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070807/79f5da25/attachment.html>
