[Swift-devel] Re: Falkon code and logs
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Tue Aug  7 11:54:28 CDT 2007
OK, made it through all the commits, but now its asking for a user id
and pass.  Who do I ask to reset my pass?
Ioan
Mihael Hategan wrote:
> Remove the build directory.
> cd ~/java/svn/falkon/service
> svn rm build
> svn ci
> On Tue, 2007-08-07 at 11:18 -0500, Ioan Raicu wrote:
>> Hi Ben,
>> I finally took the plunge, and wanted to see how SVN works :)  Thanks
>> for setting it up, I think its going to come in very useful, as
>> several people are about to start editing the Falkon code... Catalin,
>> Zhao, you, maybe Mihael, myself, etc...
>> I did the svn co....
>> did a little house cleaning, removed some files, moved others, edited
>> some scripts, did a clean, make, and run to test things.... and now I
>> wanted to commit all my changes.
>> I did:
>> iraicu at viper:~/java/svn/falkon> svn commit
>> svn: Commit failed (details follow):
>> svn: Working copy '/home/iraicu/java/svn/falkon/service/build' is
>> missing or not locked
>> My compile scripts are set to remove the service/build directory, and
>> it gets created new every time you compile the service.  Is this a
>> problem?  My guess is that the service/build directory should not be
>> in SVN, as it gets generated at compile time!
>> Any hints on what I can do to commit my changes?
>> Thanks,
>> Ioan
>> Ben Clifford wrote:
>>> On Mon, 16 Jul 2007, Ioan Raicu wrote:
>>>> Hey Ben,
>>>> Here is the latest Falkon code base, including all compiled classes, scripts,
>>>> libraries, 1.4 JRE, ploticus binaries, GT4 WS-core container, web server,
>>>> etc... its the entire branch that is needed containing all the different
>>>> Falkon components.  I would have preffered to clean things up a bit, but here
>>>> it is, and I'll do the clean-up later...
>>>> http://people.cs.uchicago.edu/~iraicu/research/Falkon/Falkon_v0.8.1.tgz
>>> I just imported this into the vdl2 subversion repo.
>>> Type:
>>>    svn co https://svn.ci.uchicago.edu/svn/vdl2/falkon
>>> to get the checkout.
>>> I removed the embedded JRE (putting aside issues of whether we should big
>>> binaries like that in the SVN, a quick glance at the JRE redistribution
>>> licence looked like it was not something acceptable)
>>> If you edit files, you can commit them with:
>>>  svn commit
>>> which will require you to feed in your CI password.
>>> Type svn update in the root directory of your checkout to pull down
>>> changes that other people have made since your last checkout/update
>>> (probably you'll find me making a bunch of those to tidy some things up)
>>> If you add files, you will need to:
>>>  svn add myfile.java
>>> before committing it.
>>> This is the tarball as I received it, so has lots of built cruft in there
>>> (.class files and things).
>>> I'll help work on tidying that up in the repository.
>>> Please commit any changes you have made since this tarball, and begin
>>> making your releases from committed SVN code rather than from your own
>>> private codebase - that way, people can talk about 'falkon built from
>>> r972' and then everyone can look at the exact code version from SVN.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070807/4918337a/attachment.html>
