[Swift-devel] Re: Falkon code and logs
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Tue Aug  7 11:18:16 CDT 2007
Hi Ben,
I finally took the plunge, and wanted to see how SVN works :)  Thanks
for setting it up, I think its going to come in very useful, as several
people are about to start editing the Falkon code... Catalin, Zhao, you,
maybe Mihael, myself, etc...
I did the svn co....
did a little house cleaning, removed some files, moved others, edited
some scripts, did a clean, make, and run to test things.... and now I
wanted to commit all my changes.
I did:
iraicu at viper:~/java/svn/falkon> svn commit
svn: Commit failed (details follow):
svn: Working copy '/home/iraicu/java/svn/falkon/service/build' is
missing or not locked
My compile scripts are set to remove the service/build directory, and it
gets created new every time you compile the service.  Is this a
problem?  My guess is that the service/build directory should not be in
SVN, as it gets generated at compile time!
Any hints on what I can do to commit my changes?
Ioan
Ben Clifford wrote:
> On Mon, 16 Jul 2007, Ioan Raicu wrote:
>> Hey Ben,
>> Here is the latest Falkon code base, including all compiled classes, scripts,
>> libraries, 1.4 JRE, ploticus binaries, GT4 WS-core container, web server,
>> etc... its the entire branch that is needed containing all the different
>> Falkon components.  I would have preffered to clean things up a bit, but here
>> it is, and I'll do the clean-up later...
>> http://people.cs.uchicago.edu/~iraicu/research/Falkon/Falkon_v0.8.1.tgz
> I just imported this into the vdl2 subversion repo.
> Type:
>    svn co https://svn.ci.uchicago.edu/svn/vdl2/falkon
> to get the checkout.
> I removed the embedded JRE (putting aside issues of whether we should big
> binaries like that in the SVN, a quick glance at the JRE redistribution
> licence looked like it was not something acceptable)
> If you edit files, you can commit them with:
>  svn commit
> which will require you to feed in your CI password.
> Type svn update in the root directory of your checkout to pull down
> changes that other people have made since your last checkout/update
> (probably you'll find me making a bunch of those to tidy some things up)
> If you add files, you will need to:
>  svn add myfile.java
> before committing it.
> This is the tarball as I received it, so has lots of built cruft in there
> (.class files and things).
> I'll help work on tidying that up in the repository.
> Please commit any changes you have made since this tarball, and begin
> making your releases from committed SVN code rather than from your own
> private codebase - that way, people can talk about 'falkon built from
> r972' and then everyone can look at the exact code version from SVN.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070807/a4aa987b/attachment.html>
