[Swift-devel] Q about MolDyn
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Mon Aug  6 15:57:24 CDT 2007
Nope, nothing more really...
Several of these:
2007-08-06 14:46:58,562 DEBUG TaskImpl Task(type=1, identity=urn:
0-1-67-0-1186429255847) setting status to Failed
0-1-69-0-1186429255851) setting status to Failed
0-1-68-0-1186429255859) setting status to Failed
0-1-70-0-1186429255863) setting status to Failed
Nothing more specific...
The log is huge. If you tell me what string to grep for - I might be
able to find something relevant...
NIka
On Aug 6, 2007, at 3:52 PM, Mihael Hategan wrote:
> On Mon, 2007-08-06 at 15:17 -0500, Veronika Nefedova wrote:
>> OK. There is something weird happening. I've got several such entries
>> in my swift log:
>> 2007-08-06 14:46:58,565 DEBUG vdl:execute2 Application exception:
>> Task failed
>>          task:execute @ vdl-int.k, line: 332
>>          vdl:execute2 @ execute-default.k, line: 22
>>          vdl:execute @ MolDyn-244-loops.kml, line: 20
>>          antchmbr @ MolDyn-244-loops.kml, line: 2845
>>          vdl:mains @ MolDyn-244-loops.kml, line: 2267
> That doesn't say much. Any more details in the logs?
>> Looks like antechamber has failed (?). And the failure is only on a
>> swfit side, it never made it across to Falcon (there are no remote
>> directories created). But I see some of antechamber jobs have
>> finished (in shared).
>> Yuqing -- could the changes you've made be responsible for these
>> failures (I do not see how it could though) ?
>> Ioan, what do you see in your logs ion these tasks:
>> 2007-08-06 14:46:58,555 DEBUG TaskImpl Task(type=1, identity=urn:
>> 0-1-56-0-1186429255786) setting status to Failed
>> 2007-08-06 14:46:58,556 DEBUG TaskImpl Task(type=1, identity=urn:
>> 0-1-57-0-1186429255798) setting status to Failed
>> 2007-08-06 14:46:58,558 DEBUG TaskImpl Task(type=1, identity=urn:
>> 0-1-59-0-1186429255800) setting status to Failed
>> 0-1-60-0-1186429255805) setting status to Failed
>> 0-1-61-0-1186429255811) setting status to Failed
>> 0-1-58-0-1186429255814) setting status to Failed
>> Nika
>> On Aug 6, 2007, at 2:29 PM, Ioan Raicu wrote:
>>> OK!
>>> Why don't we do one last run from my allocation, as everything is
>>> set up already and ready to go!  Make sure to enable all debug
>>> logging.  Falkon is up and running with all debug enabled!
>>> Falkon location is unchanged from the last experiment.
>>> Falkon Factory Service: http://tg-viz-login2:50010/wsrf/services/
>>> GenericPortal/core/WS/GPFactoryService
>>> Web Server (graphs): http://tg-viz-login2.uc.teragrid.org:51000/
>>> index.htm
>>> ANL/UC is not quite so idle as it was earlier, but I bet we could
>>> still get 150~200 processors!
>>> Ioan
>>>> m050 and m179 finished just fine now via GRAM (thanks to Yuqing
>>>> who fixed the m179 just in time!). We could start again the 244-
>>>> molecule run to verify that nothing is wrong with the whole system.
>>>> Nika
>>>> On Aug 6, 2007, at 12:20 PM, Veronika Nefedova wrote:
>>>>> On Aug 6, 2007, at 11:51 AM, Ioan Raicu wrote:
>>>>> I started those 2 molecules via GRAM. I have no trust in m179
>>>>> finishing completely since I didn't change anything. I hope for
>>>>> m050 to finish though...
>>>>> You can watch the swift log on viper in ~nefedova/alamines/
>>>>> MolDyn-2-loops-be9484k93kk21.log
>>>>> Nika
>>>>>> Then, let's try another run with 244 molecules soon, as most of
>>>>>> ANL/UC is free!
>>>>>> Ioan
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
