[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Aug  6 11:34:42 CDT 2007
Aha, OK, it didn't click that (2) was referring to the Swift log that I
was referring to.  So, in that case, we can't do much else on this run,
other than make sure we fix the infamous m179 molecule, turn on all
debugging (and make sure its actually printing debug statements), and
try the run again!
Ioan
Veronika Nefedova wrote:
> Ioan, I can't answer any of your questions -- read my point number 2
> below );
> Nika
> On Aug 6, 2007, at 11:25 AM, Ioan Raicu wrote:
>> Hi,
>>> Ok, here is what happened with the last 244-molecule run.
>>> 1. First of all, the new swift code (with loops etc) was used. The
>>> code's size is dramatically reduced:
>>> -rw-r--r--  1 nefedova users 13342526 2007-07-05 12:01 MolDyn-244.dtm
>>> -rw-r--r--  1 nefedova users    21898 2007-08-03 11:00
>>> MolDyn-244-loops.swift
>>> 2. I do not have the log on the swift size (probably it was not
>>> produced because I put in the hack for output reduction and log
>>> output was suppressed -- it can be fixed easily)
>>> 3. There were 2 molecules that failed.  That infamous m179 failed at
>>> the last step (3 re-tries). Yuqing -- its the same molecule you said
>>> you fixed the antechamber code for. You told me to use the code in
>>> your home directory  /home/ydeng/antechamber-1.27, I assumed it was
>>> on tg-uc. Is that correct? Or its on another host? Anyway, I used
>>> the code from the directory above and it didn't work. The output
>>> is @tg-login1:/disks/scratchgpfs1/iraicu/ModLyn/MolDyn-244-loos-bm66sjz1li5h1/shared.
>>> I could try to run again this molecule specifically in case it works
>>> for you.
>>> 4.  The second molecule that failed is m050. Its quite a mystery why
>>> it failed: it finished the 4-th stage (those 68 charm jobs)
>>> successfully (I have the data in shared directory on tg-uc) but then
>>> the 5-th stage has never started! I do not see any leftover
>>> directories from the 5-th stage for m050 (or any other stages for
>>> m050 for that matter). So it was not a job failure, but job
>>> submission failure (since no directories were even created). It had
>>> to be a job called 'generator_cat' with a parameter 'm050'. Ioan -
>>> is that possible to rack  what happened to this job in Falcon logs?
>> There were only 3 jobs that failed in the Falkon logs, so I presume
>> that those were from (3) above.  I also forgot to enable any debug
>> logging, as the settings were from some older high throughput
>> experiments, so I don't have a trace of all the task descriptions and
>> STDOUT and STDERR.  About the only thing I can think of is... can you
>> summarize from the Swift log, how many submitted jobs there were, how
>> many success and how many failed?  At least maybe we can make sure
>> that the Swift log is consistent with the Falkon logs.  Could it be
>> that a task actually fails (say it doesn't produce all the output
>> files), but still returns an exit code of 0 (success)?  If yes, then
>> would Swift attempt the next task that needed the missing files and
>> likely fail while executing due to not finding all the files?
>> Now, you mention that it could be a job submission failure... but
>> wouldn't this be explicit in the Swift logs, that it tried to submit
>> and it failed?
>> Here is the list of all tasks that Falkon knows of:
>> http://tg-viz-login1.uc.teragrid.org:51000/service_logs/GenericPortalWS_taskPerf.txt
>> Can you produce a similar list of tasks (from the Swift logs), if the
>> task ID (urn:0-1-10-0-1186176957479), and the status (i.e. submitted,
>> success, failed, etc)?  I believe that the latest provisioner code
>> you had (which I hope it did not get overwritten by SVN as I don't
>> know if it was ever checked in, and I don't remember when it was
>> changed, before or after the commit to SVN) should have printed at
>> each submission to Falkon the task ID in the form it is above, and
>> the status of the task at that point in time.  Assuming this
>> information is in the Swift log, you should be able to grep for these
>> lines and produce a summary of all the tasks, that we can then
>> cross-match with Falkon's logs.  Which one is the Swift log for this
>> latest run on viper?  There are so many, and I can't tell which one
>> it is.
>> Ioan
>>> 5. I can't restart the workflow since this bug/feature has not been
>>> fixed: http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=29 (as long
>>> as I use the hack for output reduction -- restarts do not work).
>>> Nika
>>> On Aug 3, 2007, at 11:03 PM, Ioan Raicu wrote:
>>>> Hi,
>>>> Nika can probably be more specific, but the last time we ran the
>>>> 244 molecule MolDyn, the workflow failed on the last few jobs, and
>>>> the failures were application specific, not Swift or Falkon.  I
>>>> believe the specific issue that caused those jobs to fail has been
>>>> resolved.
>>>> We have made another attempt at the MolDyn 244 molecule run, and
>>>> from what I can tell, it did not complete successfully again.  We
>>>> were supposed to have 20497 jobs...
>>>> 1 	1 	1
>>>> 1 	244 	244
>>>> 1 	244 	244
>>>> 68 	244 	16592
>>>> 1 	244 	244
>>>> 11 	244 	2684
>>>> 1 	244 	244
>>>> 1 	244 	244
>>>> 	20497
>>>> but we have:
>>>> 20482 with exit code 0
>>>> 1 with exit code -3
>>>> 2 with exit code 253
>>>> I forgot to enable the debug at the workers, so I don't know what
>>>> the STDOUT and STDERR was for these 3 jobs.  Given that Swift
>>>> retries 3 times a job before it fails the workflow, my guess is
>>>> that these 3 jobs were really the same job failing 3 times.  The
>>>> failure occurred on 3 different machines, so I don't think it was
>>>> machine related.  Nika, can you tell from the various Swift logs
>>>> what happened to these 3 jobs?  Is this the same issue as we had on
>>>> the last 244 mol run?  It looks like we failed the workflow with 15
>>>> jobs to go.
>>>> The graphs all look nice, similar to the last ones we had.  If
>>>> people really want to see them, I can generate them again.
>>>> Otherwise, look at
>>>> http://tg-viz-login1.uc.teragrid.org:51000/index.htm to see the
>>>> last 10K samples of the experiment.
>>>> Nika, after you try to figure out what happened, can you simply
>>>> retry the workflow, maybe it will manage to finish the last 15
>>>> jobs.  Depending on what problem we find, I think we might conclude
>>>> that 3 retries is not enough, and we might want to have a higher
>>>> number as the default when running with Falkon.  If the error was
>>>> an application error, then no matter how many retries we have, it
>>>> won't make any difference.
>>>> Ioan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070806/48354e99/attachment.html>
