[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Aug  6 11:25:47 CDT 2007
Veronika Nefedova wrote:
> Ok, here is what happened with the last 244-molecule run.
> 1. First of all, the new swift code (with loops etc) was used. The
> code's size is dramatically reduced:
> -rw-r--r--  1 nefedova users 13342526 2007-07-05 12:01 MolDyn-244.dtm
> -rw-r--r--  1 nefedova users    21898 2007-08-03 11:00
> MolDyn-244-loops.swift
> 2. I do not have the log on the swift size (probably it was not
> produced because I put in the hack for output reduction and log output
> was suppressed -- it can be fixed easily)
> 3. There were 2 molecules that failed.  That infamous m179 failed at
> the last step (3 re-tries). Yuqing -- its the same molecule you said
> you fixed the antechamber code for. You told me to use the code in
> your home directory  /home/ydeng/antechamber-1.27, I assumed it was on
> tg-uc. Is that correct? Or its on another host? Anyway, I used the
> code from the directory above and it didn't work. The output
> is @tg-login1:/disks/scratchgpfs1/iraicu/ModLyn/MolDyn-244-loos-bm66sjz1li5h1/shared.
> I could try to run again this molecule specifically in case it works
> for you.
> 4.  The second molecule that failed is m050. Its quite a mystery why
> it failed: it finished the 4-th stage (those 68 charm jobs)
> successfully (I have the data in shared directory on tg-uc) but then
> the 5-th stage has never started! I do not see any leftover
> directories from the 5-th stage for m050 (or any other stages for m050
> for that matter). So it was not a job failure, but job submission
> failure (since no directories were even created). It had to be a job
> called 'generator_cat' with a parameter 'm050'. Ioan - is that
> possible to rack  what happened to this job in Falcon logs?
There were only 3 jobs that failed in the Falkon logs, so I presume that
those were from (3) above.  I also forgot to enable any debug logging,
as the settings were from some older high throughput experiments, so I
don't have a trace of all the task descriptions and STDOUT and STDERR.
About the only thing I can think of is... can you summarize from the
Swift log, how many submitted jobs there were, how many success and how
many failed?  At least maybe we can make sure that the Swift log is
consistent with the Falkon logs.  Could it be that a task actually fails
(say it doesn't produce all the output files), but still returns an exit
code of 0 (success)?  If yes, then would Swift attempt the next task
that needed the missing files and likely fail while executing due to not
finding all the files?
Now, you mention that it could be a job submission failure... but
wouldn't this be explicit in the Swift logs, that it tried to submit and
it failed?
Here is the list of all tasks that Falkon knows of:
http://tg-viz-login1.uc.teragrid.org:51000/service_logs/GenericPortalWS_taskPerf.txt
Can you produce a similar list of tasks (from the Swift logs), if the
task ID (urn:0-1-10-0-1186176957479), and the status (i.e. submitted,
success, failed, etc)?  I believe that the latest provisioner code you
had (which I hope it did not get overwritten by SVN as I don't know if
it was ever checked in, and I don't remember when it was changed, before
or after the commit to SVN) should have printed at each submission to
Falkon the task ID in the form it is above, and the status of the task
at that point in time.  Assuming this information is in the Swift log,
you should be able to grep for these lines and produce a summary of all
the tasks, that we can then cross-match with Falkon's logs.  Which one
is the Swift log for this latest run on viper?  There are so many, and I
can't tell which one it is.
Ioan
> 5. I can't restart the workflow since this bug/feature has not been
> fixed: http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=29 (as long
> as I use the hack for output reduction -- restarts do not work).
> Nika
> On Aug 3, 2007, at 11:03 PM, Ioan Raicu wrote:
>> Hi,
>> Nika can probably be more specific, but the last time we ran the 244
>> molecule MolDyn, the workflow failed on the last few jobs, and the
>> failures were application specific, not Swift or Falkon.  I believe
>> the specific issue that caused those jobs to fail has been resolved.
>> We have made another attempt at the MolDyn 244 molecule run, and from
>> what I can tell, it did not complete successfully again.  We were
>> supposed to have 20497 jobs...
>> 1 	1 	1
>> 1 	244 	244
>> 1 	244 	244
>> 68 	244 	16592
>> 1 	244 	244
>> 11 	244 	2684
>> 1 	244 	244
>> 1 	244 	244
>> 	20497
>> but we have:
>> 20482 with exit code 0
>> 1 with exit code -3
>> 2 with exit code 253
>> I forgot to enable the debug at the workers, so I don't know what the
>> STDOUT and STDERR was for these 3 jobs.  Given that Swift retries 3
>> times a job before it fails the workflow, my guess is that these 3
>> jobs were really the same job failing 3 times.  The failure occurred
>> on 3 different machines, so I don't think it was machine related.
>> Nika, can you tell from the various Swift logs what happened to these
>> 3 jobs?  Is this the same issue as we had on the last 244 mol run?
>> It looks like we failed the workflow with 15 jobs to go.
>> The graphs all look nice, similar to the last ones we had.  If people
>> really want to see them, I can generate them again.  Otherwise, look
>> at http://tg-viz-login1.uc.teragrid.org:51000/index.htm to see the
>> last 10K samples of the experiment.
>> Nika, after you try to figure out what happened, can you simply retry
>> the workflow, maybe it will manage to finish the last 15 jobs.
>> Depending on what problem we find, I think we might conclude that 3
>> retries is not enough, and we might want to have a higher number as
>> the default when running with Falkon.  If the error was an
>> application error, then no matter how many retries we have, it won't
>> make any difference.
>> Ioan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070806/312b6c66/attachment.html>
